Samsung S6 404SC Unlock By Z3X Box
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi thanhnamPDAviet, 27/2/17.
  1. 27/2/17 lúc 09:22
    thanhnamPDAviet
    thanhnamPDAviet
    Nhận Unlock - Mở Mạng Samsung S6 404SC Qua Teamviewer
    Mã:
    Operation: Unlock
    Selected model: 404SC
    Selected port: COM112 SAMSUNG Mobile USB Serial Port
    Software version: 27.7
    Reading phone info...
    Reading IMEI... Ok
    IMEI: 358633060396674
    Unlocking... Ok
    Reseting... Ok
    Unlock done
    Mobileservices thích bài này.
  2. 23/4/17 lúc 12:08
    thanhnamPDAviet
    thanhnamPDAviet
    Unlock Samsung S6 404SC By Z3X Pro
    1. Power on the phone.
    2. Type *#0808# and select 'DM+MODEM+ADB'.
    3. Type *#9090# and select 'DM/DUN over HSIC'.
    Mã:
      UNLOCK INSTRUCTIONS:
    	 Or use 'Activate Diag' function from 'Repair' tab.
      4. Connect phone to PC with USB cable, install drivers if needed.
      5. Select diagnostic port in port settings.
      5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
    Operation: Unlock
    Selected port: COM122 SAMSUNG Mobile USB Serial Port
    Software version: 27.8
    Reading IMEI... Ok
    IMEI: 358633060347255
    Unlocking... Ok
    Reseting... Ok
    Unlock done
  3. 23/4/17 lúc 12:11
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung S6 Edge Au Jav 404SC Unlock By Z3X
    Mã:
    @thanhnamPDAviet 23-4-2017
    Operation: Unlock
    Selected port: COM88 SAMSUNG Mobile USB Serial Port
    Software version: 28.1
    Reading IMEI... Ok
    IMEI: 35863306079XXXX
    Unlocking... Ok
    Reseting... Ok
    Unlock done
    vo van son thích bài này.
  4. 20/7/17 lúc 08:36
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung S6 404SC Khóa Sim Mạng Softbank Japan
    Samsung S6 404SC 7.0 Unlock By Z3X Pro
    Samsung S6 404SC 7.0 Mở Mạng By Z3X Pro
    Tags : 404SC Unlock,404SC Mở Mạng,404SC,
    Hỗ Trợ Unlock Online Qua Teamviewer Cho Khách Hàng Ở Xa
    Mã:
    @thanhnamPDAviet
    Reading IMEI... OK
    IMEI: 358633060309537
    Unlocking... OK
    Reseting... OK
    Unlock done
  5. 18/8/17 lúc 08:24
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung S6 Edge 404SC Khóa Sim Mạng Softbank Japan
    Samsung S6 Edge 404SC Unlock By Z3X Pro
    Mã:
    @thanhnamPDAviet
    Operation: Unlock
    Selected port: COM10 SAMSUNG Mobile USB Serial Port
    Software version: 29.0
    Reading IMEI... OK
    IMEI: 358633060318XXX
    Unlocking... OK
    Reseting... OK
    Unlock done
  6. 5/10/17 lúc 09:39
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung S6 404SC Khóa Sim Nhà Mạng SoftBank Japan
    Samsung S6 SoftBank 404SC Unlock Network By Z3X Pro
    Samsung S6 SoftBank 404SC Unlock Network Via Teamviewer
    Mã:
    @thanhnamPDAviet
    Reading IMEI... OK
    IMEI: 35863306059XXXX
    Unlocking... OK
    Reseting... OK
    Unlock done
  7. 1/2/18 lúc 14:56
    vo van son
    vo van son
    il6)il6)il6)il6)
  8. 2/2/18 lúc 08:51
    thanhnamPDAviet
    thanhnamPDAviet
    Nhận hàng
  9. 5/2/18 lúc 13:27
    vo van son
    vo van son
    kkkaaaa
    thanhnamPDAviet thích bài này.
  10. 18/5/18 lúc 07:32
    thinhbdsy
    thinhbdsy
    mình cũng báo như vậy mà khởi động lại thì vẫn ko đc. thế là sao?
  11. 18/5/18 lúc 08:28
    thanhnamPDAviet
    thanhnamPDAviet
    Unlock báo done vẫn lock hay sao b
  12. 18/5/18 lúc 08:50
    thinhbdsy
    thinhbdsy
    vâng nó báo done mà vẫn lock
  13. 18/5/18 lúc 08:55
    thinhbdsy
    thinhbdsy
    Vậy mà vẫn bị lock
  14. 18/5/18 lúc 09:14
    Gsm_songcong
    Gsm_songcong
    Nâng lên bản cao nhất đi ,24,3 nghi tool crack ah
  15. 18/5/18 lúc 09:29
    thanhnamPDAviet
    thanhnamPDAviet
