Samsung 403SC Unlock By Z3X ProMã:Go to Menu->Settings->Applications->Development Turn on "USB Debugging" option When message is appear press "Yes" Go to Calculator application Enter (+30012012732+ to get phone factory mode Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab.Nhận Unlock Samsung 403SC Qua Teamviewer Mã:thanhnamPDAviet Reading phone info... Reading IMEI... Ok IMEI: 35708406045XXXX Unlocking... Ok Reseting... Ok Unlock done
Samsung 403SC Khóa Sim Nhà Mạng Softbank Japan Samsung 403SC Unlock Sim By Z3X ProMã:@ thanhnamPDAviet UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: 403SC Selected port: COM89 SAMSUNG Mobile USB Serial Port Software version: 28.6 Reading phone info... Reading IMEI... OK IMEI: 357084061350289 Unlocking... OK Reseting... OK Unlock done
