nhờ anh em xem giúp log con 5800
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi hoanganh AT, 7/2/15.
  1. 7/2/15 lúc 12:53
    hoanganh AT
    hoanganh AT
    bi mật khẩu chạy lại.bay giờ lên nokia rồi sọc màn hình.tắt nguồn luôn
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0859FEE
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000A087
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.84
    Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
    Processing MCU file: RM-356_60.0.003_prd.core.C00
    [BB5,XSR 1.5] size: 110.45 MB
    Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
    Make sure USB cable, Battery and charger are removed from device.
    Insert USB cable, Battery back to device(make sure to have fully charged battery).
    Insert Charger or Press phone's power button(if flashing doesnt start automatically)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 19D00107A69C8E52017197F8CC48433FB209E49D
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
    CMT ROM ID: 4B9B75103E691FF8
    Loading CMT secondary boot code
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Loading CMT update server data
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    CERT backup skipped due to protocol limitation.
    CMT PAPUBKEYS is blank/erased.
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 158.19 MB
    CMT FLASH,MuxOneNAND area [00040000-00082FFF]
    CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
    CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
    CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*ENO block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 1 min 58.844 s
    Processing PPM file: RM-356_60.0.003_prd.rofs2.V20
    [BB5,XSR 1.5] size: 17.96 MB
    Erase size: 31.87 MB
    CMT FLASH,MuxOneNAND area [07180000-0915FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 19.422 s
    Processing CNT file: RM-356_60.0.001_026_000_U01.uda.fpsx
    [BB5,XSR 1.5] size: 7.09 MB
    Erase size: 88.75 MB
    CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF]
    Programming completed in 8.844 s
    Processing APE User Area file: RM-356_60.0.003_C04_prd.rofs3.fpsx
    [BB5,XSR 1.5] size: 946.12 KB
    Erase size: 13 MB
    CMT FLASH,MuxOneNAND area [09160000-09E5FFFF]
    CMT SOS+ROFS3 block sent
    Programming completed in 1.094 s
    Total time for flashing process(boot+erase+write) was 3 min 11.032 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Waiting for device boot up ...
    Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet (), PORT_ID: 3AE269BB
    Verifying communication to device OK.
    Phone type: RM-356 (Nokia 5800 XpressMusic)
    SW version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia
    ApeCoreSw: V 60.0.003
    Imei plain: 12345610654321-?
    Battery voltage: 3672 mV, current: 178 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK invalid!
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei plain is invalid !!!
    SIMLOCK_DATA corrupted!
    Market items is empty, please select the correct products path !
  2. 7/2/15 lúc 12:56
    Xuân Toàn
    Xuân Toàn
    banh simlock rồi
    SIMLOCK invalid!
    SIMLOCK_TEST passed
  3. 7/2/15 lúc 12:57
    BomTấn_VFS
    BomTấn_VFS
    => write pm sx4 1 và 309 thử xem pác .
  4. 7/2/15 lúc 13:02
    hoanganh AT
    hoanganh AT
    ban nói rõ hộ mình xem.
  5. 7/2/15 lúc 13:06
    bi_sony2007
    bi_sony2007
    Chắc nhìn dòng này nhỉ :
    :D
    Nhưng kéo lên tí , thấy dòng này :
    Trả ngay và luôn. Nếu có cặp thì thay vô.
