Z1 C6903 FLAST báo lỗi XIN giúp
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi QL_mobile, 6/6/16.
  1. 6/6/16 lúc 09:42
    QL_mobile
    QL_mobile
    nhận nâng cấp cây z1 lên 5.0.2 mà toàn báo lỗi như này.
    06/040/2016 09:40:01 - INFO - <- This level is successfully initialized
    06/040/2016 09:40:01 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00
    06/040/2016 09:40:05 - INFO - Selected C6903 / 14.5.A.0.270 / RU
    06/040/2016 09:40:06 - INFO - Preparing files for flashing
    06/040/2016 09:40:06 - ERROR - Cannot delete c:\FLASHT~1\.\firmwares\prepared\boot
    06/040/2016 09:40:06 - INFO - Cannot open bundle. Flash operation canceled
    06/040/2016 09:40:08 - INFO - Device connected with USB debugging off
    06/040/2016 09:40:08 - INFO - For 2011 devices line, be sure you are not in MTP mode
    06/040/2016 09:40:12 - INFO - Device disconnected
    06/040/2016 09:40:15 - INFO - Device connected in flash mode
    06/040/2016 09:40:21 - INFO - Device disconnected
    06/040/2016 09:40:26 - INFO - Device connected in flash mode
    06/040/2016 09:40:36 - INFO - Device disconnected
    06/040/2016 09:40:39 - INFO - Device connected in flash mode
    06/040/2016 09:40:45 - INFO - Device disconnected
    06/040/2016 09:40:49 - INFO - Device connected in flash mode
    06/040/2016 09:40:56 - INFO - Device disconnected
    06/041/2016 09:41:02 - INFO - Device connected in flash mode
    06/041/2016 09:41:06 - INFO - Device disconnected
    06/041/2016 09:41:10 - INFO - Device connected in fastboot mode
    06/041/2016 09:41:11 - INFO - Device disconnected
    06/041/2016 09:41:14 - INFO - Device connected in flash mode
    06/041/2016 09:41:31 - INFO - Please connect your device into flashmode.
    06/041/2016 09:41:32 - INFO - Opening device for R/W
    06/041/2016 09:41:32 - INFO - Reading device information
    06/041/2016 09:41:32 - INFO - Phone ready for flashmode operations.
    06/041/2016 09:41:32 - INFO - Current device : C6903 - BH902XTS0D - 1276-7948_R6C - 1272-6084_14.5.A.0.270 - GLOBAL-LTE_14.3.A.0.757
    06/041/2016 09:41:32 - INFO - Processing loader.sin
    06/041/2016 09:41:32 - INFO - Checking header
    06/041/2016 09:41:32 - INFO - Flashing data
    06/041/2016 09:41:32 - INFO - Loader : S1_Root_6732 - Version : MSM8974_23 / Boot version : S1_Boot_MSM8974_Rhine1.3_LA1.04_11 / Bootloader status : ROOTABLE
    06/041/2016 09:41:32 - INFO - Start Reading unit 000008B2
    06/041/2016 09:41:32 - INFO - Reading TA finished.
    06/041/2016 09:41:32 - INFO - Ending flash session
    06/041/2016 09:41:32 - INFO - Now unplug your device and restart it into fastbootmode
    06/041/2016 09:41:33 - INFO - Device connected in flash mode
    06/041/2016 09:41:33 - INFO - Device disconnected
    06/041/2016 09:41:35 - INFO - Device connected in flash mode
    06/041/2016 09:41:36 - INFO - Bootloader unlock canceled
    AE gặp qua xin giúp em phát.giờ máy chỉ lên sony rồi xanh màn hinh.
  2. 6/6/16 lúc 09:59
    QuangĐông-gsm
    QuangĐông-gsm
    đòi unclock loader rồi flash mà .thớt unclock nhanh mà lcus hiện ra bảng đánh imei cái done mà ,làm đi làm lại vào
  3. 6/6/16 lúc 11:19
    QL_mobile
    QL_mobile
    giờ máy treo có cách nào kiểm tra được imei không bác
