xin rom IP XS MAX mt6580 6.0
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi damxuanquang, 2/12/19.
  1. 2/12/19 lúc 10:34
    damxuanquang
    damxuanquang
    Như tiêu đề mình cần rom con ip xs max mt6580 6.0, nhận máy mất hết ICON trên mh, chỉ còn 3 cái ICON là camera, file manager, và Call, ae có máy read giúp hoặc có rom share mình với, cảm ơn ae xem tin!
    Log info cm2:
    Wait for phone...
    Phone found! [ 148 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6580
    BB_CPU_NME : [MediaTek] MT6580_S00
    BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x00000000
    BromVer : 0x00FF
    BLVersion : 0x0001
    PreLoader : Active [ Boot with PL ]
    BootLdrSS : NORMAL with PRELOADER
    Processing DA stage
    DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x94
    NAND Flash : NOT INSTALLED
    eMMC Flash : 1501004B385530304D03B20F122731B5
    Initialize Memory ...
    DRAM already initialized by Preloader
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0x15 , OEM : 0100
    [eMMC] : FLASH_INF : [SAMSUNG] , M00U8
    [eMMC] : FLASH_CID : 1501004B385530304D03B20F122731B5
    [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
    [eMMC] : FLASH_LEN : 0x00000003A3E00000
    [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
    DEV RID : 0x1E21FD52638837D31C50BB51B8D2B8F6
    INT RAM : 0x00020000
    EXT RAM : 0x40000000 [1 GiB]
    BOOT TYPE : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    [AP] : Initial info read Ok!
    Brand : Apple
    ProdName : iPhone
    ProdModel : XS_Max
    Device : IPhone_XS_Max
    AndroidVer: 6.0
    MTKxCPU : MT6580
    MTKxPRJ : alps-mp-m0.mp1-V2.34_hct6580.weg.c.m_P147
    SECURITY :
    IMEI_SW [1] : 354613265123684
    IMEI_SW [2] : 354643216813268
    BTMAC Addr : 123456807AFF
    WiFi MAC : 20720D40CEB0
    MODEM :
    BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P36_1_wg_n
    EXTRA :
    LCD : Not info available :(
    LCD Res : 1520x720
    TOUCH [0] : ft5206
    CAM [0] : gc2385mipi_raw
    CAM [1] : gc2355_mipi_raw
    CAM [2] : ar0543_mipi_raw
    CAM [3] : s5k3h2yx_mipi_raw
    MODEM : hct6580_we_c_m_hspa_default
    LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
    Done!
    Elapsed: 00:00:28
    Reconnect Power/Cable!
    4bf5ba8d1c80e5debc91. f379491cef11164f4f00.
  2. 2/12/19 lúc 16:16
    damxuanquang
    damxuanquang
    vẫn chưa có rom!
  3. 11/12/19 lúc 11:33
    BongmabiengioI7
    BongmabiengioI7
    inbox hướng dẫn có lại icon
    damxuanquang thích bài này.
  4. 21/12/19 lúc 13:46
    CaoDuy_Mobile
    CaoDuy_Mobile
    Anh còn rom này không vậy
    Của em bị treo
    Tìm rom chưa có
  5. 21/12/19 lúc 14:55
    tam727
    tam727
    có rom free
  6. 21/12/19 lúc 16:37
    CaoDuy_Mobile
    CaoDuy_Mobile
    cho e xin với anh ơi
  7. 21/12/19 lúc 22:19
    damxuanquang
    damxuanquang
  8. 29/4/20 lúc 10:41
    Minhtanmobilest
    Minhtanmobilest
    A ơi còn link ROM con này không cho e xin với !!! (THANKS)
