xin giúp xl lỗi như log
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi kutebin, 4/5/16.
  1. 4/5/16 lúc 20:12
    kutebin
    kutebin
    Phone Type : Nokia XL [RM-1030]
    CPU Type : Qualcomm MSM8225
    Storage TYpe : eMMC 4GB
    Boot Package : Full Boot Restore
    Firmware Version: 1.2.1.2
    1. Make sure JTAG Connection is 100% OK
    2. Always Disconnect the Phone BATTERY
    3. Connect USB Cable to Phone
    4. Connect RJ-45 JTAG Cable to ATF Box
    5. Select the Correct Phone Type RM-XXX
    6. Use RESET JTAG button to check the JTAG Connection
    7. Click RESTORE BOOT button to Start Boot Repairs
    Restore Boot...
    Waiting for Device Connection 20 second(s)...OK
    Resetting and Exploring JTAG chain...OK
    Halting Core...OK
    Initializing Device...OK
    Detecting eMMC #1 ID...1501004A3558574D4201C10ED874711D
    Flash Description: Samsung J5XWMB, 3.64 GiB, SN C10ED874, Jul 1998
    Partition Config: Boot from USER, Boot ACK OFF (0x38)
    Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
    Testing Device Memory...OK
    Sending Flash Loader...Memory Write Error, Shift IR Error(s)
  2. 4/5/16 lúc 20:14
    kutebin
    kutebin
    Halting Core...Retry
    Halting Core...OK
    Sending Flash Loader...OK (91918 Op/Sec)
    Restoring Partition #1...OK
    Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76
    Please send this log and "..\Logs\.log" file to support!
  3. 4/5/16 lúc 20:15
    kutebin
    kutebin
    ae giup em nhe. thankl alll ae
  4. 4/5/16 lúc 22:03
    Dung_travinh2006
    Dung_travinh2006
    lúc trước bị cây x cũng như vậy, ai giờ chọn file boot version khác ok
