Xin giúp Unlock Nokia
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi Hoàng Gia Hải, 23/4/17.
  1. 23/4/17 lúc 08:53
    Hoàng Gia Hải
    Hoàng Gia Hải
    mới nhận 1 con nokia 301.1 RM-840 mà ko biết unlock bằng thiết bị gì ae làm qua rồi xin giúp thanks
  2. 23/4/17 lúc 08:56
    Trieubk
    V.I.P
    Trieubk
    Info xem lock 15 số hay 20 số?
    15 số thì dò code bằng SL3 super PC, 20 số thì xem khóa mạng gì mua code.
  3. 23/4/17 lúc 08:58
    Hoàng Gia Hải
    Hoàng Gia Hải
    Number of Image Files: 3
    Processing Image File :
    rm840__08.02.mcusw
    rm840__08.02.ppm_s3
    rm840__08.02.image_s3_059R1M4
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, and 3...
    1. Remove USB Cable and Battery...
    2. Connect USB Cable.
    3. Connect Battery.
    ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT *****
    ******* REMOVE BATTERY AND PUT IT BACK AGAIN. *******
    Infineon Boot: F01650A9070100030101E0001809002415044AF09636FFFF
    CPU Type: Intel XG618
    <<<< Connect Battery Now >>>>
    Sending PBL...
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Flash Chip Manufacturer: STMicroelectronics
    Flash Boot Successful...
    Unique Data: E000180900241504
    Original Product Code: 059T0Q4
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\355520055817348\355520055817348_83943.rpl
    Current File : rm840__08.02.mcusw
    Number of Images: 8
    psi_flash_unsigned.fls
    slb_signed.fls
    main_toc_signed.fls
    rm840__08.02.mcusw_signed_mcusw.fls
    swap_signed.fls s
    dynsw.fls
    aeneas_signed.fls s
    fota_signed.fls s
    Processing Data Block 0x00
    Erase Block: 0x00090000~0x000A0FAE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Data Block Write Done...
    Processing Data Block 0x01
    Erase Block: 0x60000000~0x6003FFFE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x02
    Erase Block: 0x60040000~0x600403FE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x03
    Erase Block: 0x62E00000~0x63D0BAF2
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Erase Block: 0xFFF00000~0xFFF7FFFE
    Start Erasing...
    Block Erase Done...
    Processing Data Block 0x04
    Erase Block: 0x80000000~0x80C254B2
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x05
    Erase Block: 0x62080000~0x620C3FFE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x06
    Erase Block: 0x63F79C00~0x63FC046E
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x07
    Erase Block: 0x61F00004~0x62049872
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Current File : rm840__08.02.ppm_s3
    Number of Images: 1
    package_s3.ppm_ebl_psi.fls
    Erase Block: 0x80F00000~0x81644972
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Current File : rm840__08.02.image_s3_059R1M4
    Number of Images: 1
    package_s3_059R1M4.image.fls
    Erase Block: 0xA1000000~0xA2AB83FE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Erase Block: 0xAE000000~0xAE2FFFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:00:14
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    Scanning USB Ports...
    Basic Phone Information
    MCU Version: V 08.02 18-11-13 RM-840 (c) Nokia
    IMEI Plain : 355520055817348
    IMEI Spare : A355520055817340
    IMEI SV : 33555200558173422F
    Phone Model: Nokia 301
    Category : Phone
    Phone Type : RM-840
    Extended Phone Information
    Product Serial Number: 0D2C68ABH
    Product Code : 059Q9N1
    Module Code : 0205267
    Basic Production Code: 059P5R1
    Long Production SN : 0
    PPM SW Version : V 08.02 18-11-13 RM-840 (c) Nokia S3
    BT MCM Version : 19e2-4702G12
    ADSP Version : PMU_MAXIM8939B
    MCU SW Version : V 08.02 18-11-13 RM-840 (c) Nokia
    HW Version : 1000
    UPP Version : MFR:0x20,DEV:0x40,REV:0x131
    RFIC Version : 152
    LCD Version : TPO
    Camera : 01035602006004
    Content Pack Version : Content: s3_059R1M4 V 08.02 19-11-13 RM-840 (c) Nokia
    AHNE Version : 13
    RETU Version : PMU_MAXIM8939B
    Bluetooth ID : F4:F5:A5:50:DD:70
    CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
    ********** SIMLOCK INFO **********
    CONFIG_DATA : 5050200000000000
    PROFILE_BITS : 800000000004000B
    ASIC : 11
    PROVIDER : Optus Mobile Pty. Ltd. ;Australia [GSM]
    LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
    Block [1] 1:Close
    SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : 01035602
    DCC Ver: 006004
    Status : OK
    Selected VPL File:
    RM840_059R1M4_08.02_043.vpl
    Variant Details : RM-840 APAC_S3_CYAN_STROKE_VN
    Software Version : 08.02
    Product Type : RM-840
    Product Code : 059R1M4
    Variant Version : 043
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
  4. 23/4/17 lúc 09:02
    ThanhThảoMobile
    ThanhThảoMobile
    Optus Mobile Pty. Ltd. ;Australia [GSM].
  5. 23/4/17 lúc 09:02
    Trieubk
    V.I.P
    Trieubk
    20 số khóa optus australia, mua code thôi
  6. 23/4/17 lúc 09:06
    Hoàng Gia Hải
    Hoàng Gia Hải
    vậy là phải read hash SL3 như BB5 phải ko ạ
  7. 23/4/17 lúc 09:09
    Trieubk
    V.I.P
    Trieubk
    Đã nói là mua code chứ read hash gì, lock 15 số mới read hash.
  8. 23/4/17 lúc 09:12
    Hoàng Gia Hải
    Hoàng Gia Hải
    giá bao nhiu vậy
  9. 23/4/17 lúc 09:13
    Trieubk
    V.I.P
    Trieubk
    Không biết:D
  10. 23/4/17 lúc 09:15
    Hoàng Gia Hải
    Hoàng Gia Hải
  11. 23/4/17 lúc 09:41
    NhậtAn Mobile
    NhậtAn Mobile
    báo giá khách mua main sàng cho lẹ
