xin giúp flash 8800d rm 13 bị lỗi
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi quangtrongmobi, 28/3/15.
  1. 28/3/15 lúc 16:21
    quangtrongmobi
    quangtrongmobi
    như tiêu đề chạy con 8800d rm 13 bị lỗi này là gì vậy ae..
    Connection status: UHCI:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
    Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
    RPL backup already exist (C:\mobileEx\3.5\data\backup\35621600027479_BACK.r pl).
    Processing MCU file: rm13_33_11003.780
    [TIKU BT2,TIKU ALGORITHM] size: 9.86 MB
    Supported Ids: 1052, 2051
    ASIC ID: 0x1052 [TikuEdge ver: 1.1]
    SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
    Supported Ids: 1051, 1052, 2051
    FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
    FlashID1: 00EC 0020 [Samsung KFM1216Q2M,512 Mbits] type: NAND hw: EIJA(E)
    FlashID2: 0000 0001 [unused/removed]
    FlashID3: 0000 0001 [unused/removed]
    ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
    Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
    Performing Flash Authentication ...OK
    UEM ID: 00426F71:BDB3DA60
    Area [00000000-0000FFFF] erased in 0.630 s
    Area [00010000-009FFFFF] erased in 1 min 38.652 s
    Area [00A00000-00B3FFFF] erased in 12.373 s
    Area [00B60000-00FAFFFF] erased in 43.524 s
    Flash programming ...
    Programming completed in 1 min 7.835 s
    File processed in 3 min 52.330 s
    Processing CNT file: rm13_33_11003.78.ucp_x
    [TIKU BT2,TIKU MON CSM] size: 4.66 MB
    Supported Ids: 1052, 10C6, 2051
    Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
    Mass Memory Storage Device detected.
    Configuring MM bus ...
    Formating partition ...OK
    Opening MM device ...
    Erasing disks ...OK
    The semaphore timeout period has expired
    Error while programming [2E] at 0x01000020, Result: 0000
    flashing terminated !
  2. 28/3/15 lúc 19:11
    hienmobilemart
    hienmobilemart
    8800d là RM-165 mà thớt
  3. 29/3/15 lúc 07:27
    quangtrongmobi
    quangtrongmobi
    kiểm tra trong máy là rm 13
  4. 29/3/15 lúc 13:52
    quangtrongmobi
    quangtrongmobi
    sao ko thấy ai vào giúp vậy
