xin giúp em log nokia
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi wincaca69, 11/4/16.
  1. 11/4/16 lúc 09:21
    wincaca69
    wincaca69
    tình hình em nhận cây lumia 535 hay bị treo với reset. chạy bằng atf khoảng 70% là đúng. pin ok cấp ok đã thay đổi 2thu đó
    ai gap qua xin chi giao. thanks
    log
    Windows Phone 8/8.1/10 Flashing Started
    Loading Flash Files Please Wait...
    [DEAD BOOT REPAIR via USB is SUPPORTED]
    Windows Phone 8/8.1/10 Lumia Flasher
    If the Phone is ALIVE
    1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
    1. Connect Phone to the USB Port
    2. Press and Hold the VOLUME DOWN and POWER Buttons
    3. Wait until the Phone Vibrates Shortly...
    4. Stop Pressing the Buttons...
    If the Phone is DEAD BOOT
    2. Install Correct Drivers:
    "Nokia Emergency Connectivity" Located at:
    C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    1. Press and Hold the VOLUME DOWN and POWER
    2. Wait until the Phone Reboots...
    3. Wait until you see BIG "NOKIA" Logo
    Version: 2.5.2.11
    Product Code: 059W6K1
    Module Code: 0206286
    Basic Tranceiver Code: 059W2B7
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x09 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x1F : 01
    Block ID 0x02 : 00240000
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8212.P6214.1.1
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 01000F0000
    Block ID 0x20 : 010000000100000004
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 020222023B00
    UEFI App: FLASH APP
    Flash App Protocol Version: 2.34
    Flash App Implementation Version: 2.59
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: BC2353ACA62C327ECCD582A281CA4A5672F35001D87176CCBF3C87DBE215CA3B
    Query PUBLIC ID...
    PUBLIC_ID: 9FA139C0868C040ED69CE581FA5D2B5CCAAF2A68
    Query eMMC Info...
    EMMC Manufacture ID: SAMSUNG
    EMMC Product SN : CC51DCDF
    EMMC_SIZE: 8 Gigabytes
    Query Battery Charge Status...
    BATTERY CHARGE_STATUS: 42%
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Fixing Partitions...
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    ERROR: DATA BLOCK REJECTED at 0x4A4E0000
    Check your Flash File and Phone Connection
    ERROR: Flashing Failed!
