nhận có này tình trạng treo logo nên ko biết bản nào fang bản 8g giờ chỉ rung ko nên cần xin rom 2 ban 16g và 8g file bin ae có cho e xin với cảm ơn
ANDROID EMMC File: MT657x/83/89 Waiting for USB Port... The File Information: N/A Set Preloader And Gadget Serial (COM7) Please Hold "ON" to connect with the phone...USB Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0xD2000000 INT/EXT RAM Size: 0x0+0x0 Writing(Nand/eMMC)... Error Addr:00020800 lỗi vậy phải con này bản 16g ko nhỉ
=============== Memory Detection Report =============== Internal RAM: Size = 0x00020000 (128KB) External RAM: Type = DRAM Size = 0x40000000 (1024MB/8192Mb) NAND Flash: ERROR: NAND Flash was not detected! EMMC : EMMC_PART_BOOT1 Size = 0x0000000000400000(4MB) EMMC_PART_BOOT2 Size = 0x0000000000400000(4MB) EMMC_PART_RPMB Size = 0x0000000000400000(4MB) EMMC_PART_GP1 Size = 0x0000000000000000(0MB) EMMC_PART_GP2 Size = 0x0000000000000000(0MB) EMMC_PART_GP3 Size = 0x0000000000000000(0MB) EMMC_PART_GP4 Size = 0x0000000000000000(0MB) EMMC_PART_USER Size = 0x00000001D2000000(7456MB) ============ RAM Test ============ Data Bus Test : [D0][D1][D2][D3][D4][D5][D6][D7][D8][D9][D10][D11][D12][D13][D14][D15][D16][D17][D18][D19][D20][D21][D22][D23][D24][D25][D26][D27][D28][D29][D30][D31] OK!! Address Bus Test : [A1][A2][A3][A4][A5][A6][A7][A8][A9][A10][A11][A12][A13][A14][A15][A16][A17][A18][A19][A20][A21][A22][A23][A24][A25][A26][A27][A28][A29] OK!! RAM Pattern Test : Writing ... 0x44332211,
=============== Memory Detection Report =============== Internal RAM: Size = 0x00020000 (128KB) External RAM: Type = DRAM Size = 0x40000000 (1024MB/8192Mb) NAND Flash: ERROR: NAND Flash was not detected! EMMC : EMMC_PART_BOOT1 Size = 0x0000000000400000(4MB) EMMC_PART_BOOT2 Size = 0x0000000000400000(4MB) EMMC_PART_RPMB Size = 0x0000000000400000(4MB) EMMC_PART_GP1 Size = 0x0000000000000000(0MB) EMMC_PART_GP2 Size = 0x0000000000000000(0MB) EMMC_PART_GP3 Size = 0x0000000000000000(0MB) EMMC_PART_GP4 Size = 0x0000000000000000(0MB) EMMC_PART_USER Size = 0x00000001D2000000(7456MB) ============ RAM Test ============ Data Bus Test : [D0][D1][D2][D3][D4][D5][D6][D7][D8][D9][D10][D11][D12][D13][D14][D15][D16][D17][D18][D19][D20][D21][D22][D23][D24][D25][D26][D27][D28][D29][D30][D31] OK!! Address Bus Test : [A1][A2][A3][A4][A5][A6][A7][A8][A9][A10][A11][A12][A13][A14][A15][A16][A17][A18][A19][A20][A21][A22][A23][A24][A25][A26][A27][A28][A29] OK!! RAM Pattern Test : Writing ... 0x44332211, 0xA5A5A5A5, 0xA5A5A500, 0xA500A500, 0xA5000000, 0x00000000, 0xFFFF0000, 0xFFFFFFFF, OK!! Increment/Decrement Test : Writing ... bắt nguồn rung tắt rung..........................................
OK!! ============ NAND Test ============ SKIP! NAND Flash was not detected! ============ EMMC Test ============ EMMC Pattern Test(0x5A5A): FAILED!! có con fash mô 8gb ko chiều lên lây luôn
