Máy lúc đầu chậm reset lại treo .cho vào ATF Flast thì giờ khởi động nokia khởi động đi khởi động lại
Ver hiện tại là nhiu pác ,check code của pác ra ver 2.1.0.11 . ver pác trên là 30.06.11 nhưng rm-1011 .
em nạp ver 2.1.0.11 rồi nhưng giờ cứ lên nokia rồi khởi động lại liên tục.mình nạp bằng ATF AE cho hướng giải quyết giùm
RM1013_059W0W0_2.1.0.11_094.rar 479.3 MB https://mega.nz/#!FQQG1T4K!TvipqAcZqUwsBgkm2GaBWh2QKrcVnfRhfG9gpUWEU28 RM1013_059W0W0_2.1.0.11_101.rar 479.3 MB https://mega.nz/#!wB5TQRCQ!5BjYIYsOSW5C6JMlzEIldmkb-PW7kaon8iVe35AYzc0
Waiting for USB Cycle... USB Cycle OK! Emergency Loader Found! Sending FireHose Loader... Starting FireHose Loader... FireHose Loader Accepted! Start Sending Files... BOOT Partition Write: rm1013_2.1.0.11_user_boot.img Partition Write OK! CACHE Partition Write: rm1013_2.1.0.11_user_cache_1.img Partition Write OK! ABOOT Partition Write: rm1013_2.1.0.11_user_emmc_appsboot.mbn Partition Write OK! ABOOTBAK Partition Write: rm1013_2.1.0.11_user_emmc_appsboot.mbn Partition Write OK! MISC Partition Write: rm1013_2.1.0.11_user_misc_erase.img Partition Write OK! MODEM Partition Write: rm1013_2.1.0.11_user_NON-HLOS.bin Partition Write OK! RECOVERY Partition Write: rm1013_2.1.0.11_user_recovery.img Partition Write OK! RPM Partition Write: rm1013_2.1.0.11_user_rpm.mbn Partition Write OK! RPMBAK Partition Write: rm1013_2.1.0.11_user_rpm.mbn Partition Write OK! SBL1 Partition Write: rm1013_2.1.0.11_user_sbl1.mbn Partition Write OK! SBL1BAK Partition Write: rm1013_2.1.0.11_user_sbl1.mbn Partition Write OK! SDI Partition Write: rm1013_2.1.0.11_user_sdi.mbn Partition Write OK! TZ Partition Write: rm1013_2.1.0.11_user_tz.mbn Partition Write OK! TZBAK Partition Write: rm1013_2.1.0.11_user_tz.mbn Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_1.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_10.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_11.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_2.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_3.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_4.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_5.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_6.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_7.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_8.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_9.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_1.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_2.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_3.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_4.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_5.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_6.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_7.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059W0W0_001.custom_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_1.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_10.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_11.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_12.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_13.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_14.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_15.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_16.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_17.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_18.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_19.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_2.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_20.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_21.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_22.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_23.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_24.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_3.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_4.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_5.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_6.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_7.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_9.img Partition Write OK! Sending All Files Done! Total Flashing Time (Erase + Flashing) : 00:02:57 Restarting Phone... Wait 1 to 3 Minutes for Phone First Boot Log OK mà vẫn bị khởi động lại là sao các bác.AE cho hướng giải quyết giùm
