Number of Image Files: 3 Processing Image File : rm694__11.79.mcusw Processing Image File : rm694__11.79.ppm_v Processing Image File : rm694__11.79.image_v_059F774 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 1250240D1C091829 Original Product Code: 059D1Q2 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: H:\AdvanceBox Turbo Flasher\Nokia\Backup\352439052116641\352439052116641_121006.rpl Certificate Block Saved to: H:\AdvanceBox Turbo Flasher\Nokia\Backup\352439052116641\352439052116641_CERTIFICATE_1611E679.bin PM Block Saved to: H:\AdvanceBox Turbo Flasher\Nokia\Backup\352439052116641\352439052116641_PMM_PROT_A5AEA37C.bin Security Code: 12345 Data Sections : 04 Current File : rm694__11.79.mcusw Compile Name: rm694__11.79.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27528584 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CCF5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7ACE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: A7F4 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 26214400 bytes Data Checksum: 67B2 Uploading Data Blocks to phone... ERROR: Write Flash Failed [/IMG] máy bị lỗi, hay đứng máy flash báo lỗi như hình. bac nào gặp rồi giúp e với, khách dí quá
