x1-01 lỗi ********** SIMLOCK INFO ********** ERROR : Unable to read Simlock Info ... cần giúp
Thảo luận trong 'CÁC DÒNG ĐIỆN THOẠI PHỔ THÔNG' bắt đầu bởi neardie, 20/8/17.
  1. 20/8/17 lúc 08:56
    neardie
    neardie
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    Booting Phone...
    CPU ID Response: A200341100
    CPU Type: XG110 2.1B
    Phone Booted at after First attempt...
    TIME STARTS HERE
    Sending PBL 19456 bytes...
    PBL Successfully Sent...
    Sending SBL 65024 bytes...
    SBL Successfully Sent...
    Flash Chip Manufacturer: STMicroelectronics
    Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    Extended Information: Multiple Bank / Burst / 1.8v
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\rm713_007.500
    Data Block Found...
    Number of Sections: 03
    IMAGE Certificate Block Sent Successfully...
    Processing Section 01 of 03
    IMAGE Erase Block: 0x00000000~0x0001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 24576 bytes
    Data Checksum: 55FD
    Uploading Data Blocks to phone...
    IMAGE Data Blocks uploaded to phone...
    Processing Section 02 of 03
    IMAGE Erase Block: 0x00800000~0x00BFFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 4128768 bytes
    Data Checksum: AA06
    Processing Section 03 of 03
    IMAGE Erase Block: 0x00C5D000~0x00E5FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1697536 bytes
    Data Checksum: C1B9
    Start Data Verification... (Please wait)
    Data Verification Successful...
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\rm713_007.50mr
    Data Block Found...
    Number of Sections: 01
    Processing Section 01 of 01
    IMAGE Erase Block: 0x00100000~0x006120BE
    Start Erasing...
    Block Erase Done...
    Data Size: 5316800 bytes
    Data Checksum: 93CE
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\rm7130_nai07.50mr
    Data Block Found...
    IMAGE Erase Block: 0x00E60000~0x00F0E53E
    Start Erasing...
    Block Erase Done...
    Data Size: 714048 bytes
    Data Checksum: 111B
    Exit Flash Mode Done...
    Time Elapse : 00:04:29
    You must Factory Reset the phone to enable the
    ringtones and other customized settings to work
    Waiting For Phone to go Online...
    5, 4, 3, 2, 1...
    MCU: V 07.50 29-11-11 RM-713 (c) Nokia
    IMEI: 352830056333762
    Product Serial Number: 8E763ECAH
    Module Code : 0204727
    PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
    ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
    như tiêu đề e máy giờ lên nokia chớt đen lại lên nokia như vậy e đã đóng lại xgod bác nào biết nguyên nhân chỉ em MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
    UPP Version : 8850
    Maybe you are reading BB5 phone ...
    ST_LCD_TEST : PASSED
    FACTORY SET TO : Full Factory Set
    FAILED
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
  2. 20/8/17 lúc 08:58
    neardie
    neardie
    như tiêu đề bác nào biết chỉ giáo em với đã đóng lại cpu vẫn vậy ạ
  3. 22/8/17 lúc 06:54
    neardie
    neardie
