ViVK MT6580 Remove FRP Done
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 30/7/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
  1. 30/7/18 lúc 13:09
    thanhnamPDAviet
    thanhnamPDAviet
    ViVK MT6580 Remove FRP By CM2
    Mã:
    @thanhnamPDAviet
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6580
    BB_CPU_NME : [MediaTek] MT6580_S00
    BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x00000000
    BromVer   : 0x00FF
    BLVersion : 0x0001
    PreLoader : Active [ Boot with PL ]
    BootLdrSS : NORMAL with PRELOADER
    Processing DA stage
    DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x94
    NAND Flash : NOT INSTALLED
    eMMC Flash : F40122426977696E201000002C28C429
    [WARNING] : MEMORY_eMMC_VALIDATE_FAILED
    Initialize Memory ...
    DRAM already initialized by Preloader
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0xF4 , OEM : 0122
    [eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi
    [eMMC] : FLASH_CID : F40122426977696E201000002C28C429
    [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000
    [eMMC] : FLASH_LEN : 0x000000039A000000
    [eMMC] : FLASH_UCP : 14752 MiB [eMMC 16 GiB]
    DEV RID	: 0xF85F4F291BE9284A55C7AE8C6F484294
    INT RAM	: 0x00020000
    EXT RAM	: 0x40000000 [1 GiB]
    BOOT TYPE  : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    Clear FRP ( Google Reset Protection )
    Clear Ok!
    Done!
    Elapsed: 00:00:28
    Reconnect Power/Cable!
    doanphi_gsm thích bài này.
Trạng thái chủ đề:
