Bán Vacheron Constantin replica
Thảo luận trong 'ĐIỆN TỬ - ĐIỆN LẠNH - ĐIỆN GIA DỤNG.' bắt đầu bởi anyick, 6/5/25.
    anyick (Offline)
    Khánh Hòa
    275,000 (VNĐ)
    Chuyển Phát Nhanh
    23659874 Click để xem
    Gửi 6/5/25, 0 Trả lời, 115 Đọc
  1. 6/5/25 lúc 14:52
    anyick
    anyick
    Vacheron Constantin Traditionnelle Openface Limited Edition Trio within White Gold
    These three unique watches from Vacheron Constantin reinterpret the traditional work schedule complication through skeletonization. They may not be skeletonized replica luxury watches within the usual sense, but rather watches that invite the wearer in order to admire the inner workings with the movement rather than through it. This particular design technique is particularly relevant to dial-side complications, in which the skeletonization is not only decorative but additionally practical, revealing the system that is usually hidden, therefore truly highlighting the operation of the watch.
    All three watches are made of platinum eagle, with a partially skeletonized strong gold dial and the exact same asymmetrical Maltese cross etched. Unlike traditional motifs for example barley ears or basketweaves, this asymmetrical pattern provides a layer of complexness in both design and creation, requiring the guilloché artists to achieve a precision as high as one tenth of a millimeter. The dial is additional complicated by the integration associated with sapphire crystal. The sky-blue crystal is not mounted on the actual dial, but is exactly embedded in the dial. This involves fine milling of the precious metal to distinguish the engraved design from the transparent part. Such as the Traditionnelle Tourbillon Perpetual Calendar, the movement bridges of most three models are embellished with the “côte unique” routine. high quality watches replica
    The actual Traditionnelle Complete Calendar Skeleton is one of the few complicated timepieces created by the top Swiss watch manufacture. It interprets the traditional screen method in a more significant way, highlighting the brand's extraordinary ability to find a stability between classic watchmaking workmanship and modern style. The conventional model has a slate grey dial and anthracite connections for a more modern look, as the anniversary model has a silver precious metal dial and a lighter motion finish, which is refreshing and much more refined. www.grand-watch.co
    Technical specs: Traditionnelle complete calendar Openface
    Reference number: 4020T/000P-H038
    Movement: Automatic Calibre 2460 QCL/270; 40-hour reserve of power, 4Hz or 28, eight hundred vph
    Functions: Hrs; minutes; complete calendar along with day, date, month as well as moon phases
    Situation: 41 mm × 11.05 mm; 950 platinum; water-repellant to 30 meters
    Dial: Hand-guilloché white gold switch with 270th anniversary style inspired by the Maltese mix Strap
    : Dark blue Mississippiensis alligator leather together with alligator leather lining, hand-stitched, large square scales
