Unlock - Mở Mạng Huawei Elite (LYO-L02) (Chimera) Huawei Elite (LYO-L02) Phiên bản khóa sim nhà mạng,lắp sim đòi code. Unlock direct by Chimera,sóng full,không sai IMEI khi Unlock. Nhận Unlock - Mở Mạng Huawei Y6 Elite (LYO-L02) Online cho anh em không có Box https://vietfones.vn/forum/threads/...online-thanhnampdaviet.1224657/#post-13756899
Huawei Elite (LYO-L02) Unlock Sim By Chimera (Teamviewer) Unlock LYO-L02 cho khách ở xa,qua TeamviewerMã: [Removing network lock...] Searching for Manufacture port... Switching to diag mode. Phone version: BB chip version: mt6735,S01 DSP fw version: Thu Dec 1 17:40:27 CST 2016 DSP patch version: n/a Eco version: n/a Hardware version: LYO-L02C718B123 Melody version: S01 Software version: n/a Clearing network lock... done. Turning off the phone... done. Finished successfully. Finished at local time: [04.05.17 11:58:47] WorkID: 19682230
Huawei Elite (LYO-L02) Khóa Sim Nhà Mạng Huawei Elite (LYO-L02) Unlock By ChimeraMã:@thanhnamPDAviet Initializing... Phone version: BB chip version: mt6735,S01 DSP fw version: Thu Dec 1 17:40:27 CST 2016 DSP patch version: n/a Eco version: n/a Hardware version: LYO-L02C718B123 Melody version: S01 Software version: n/a Clearing network lock... done. Turning off the phone... done. Finished successfully. Finished at local time: [06.23.17 13:44:04]
Huawei Elite (LYO-L02) LYO-L02C718B124 Khóa Sim Nhà Mạng Huawei Elite (LYO-L02) LYO-L02C718B124 Unlock By Chimera Huawei Elite (LYO-L02) LYO-L02C718B124 Mở Mạng By Chimera Tags:LYO-L02C718B124 Unlock,LYO-L02C718B124 Mở Mạng, Mã:@thanhnamPDAviet LYO-L02C718B124 Direct Unlock 7/18/2017 8:47:11 AM Direct Unlock 7/18/2017 8:43:12 AM Direct Unlock 7/18/2017 8:40:06 AM Direct Unlock 7/18/2017 8:33:34 AM Direct Unlock 7/18/2017 8:33:16 AM [Removing network lock...] This method will overwrite the factory recovery with a custom recovery (TWRP). In some cases, it will remain permanently installed on the phone. Are you sure you want to continue? Checking bootloader... Rebooting device to fastboot mode... Device found! bootloader status: unlocked Downloading TWRP recovery... Booting recovery... Please keep pressing down the volume up button while clicking OK below. Do not release the volume up button until recovery is booted. If a menu appears on the phone, select recovery mode. Removing SIM-lock... Finished successfully. Finished at local time: [07.18.17 15:48:39]
Huawei Elite (LYO-L02) Khóa Sim Nhà Mạng Huawei Elite (LYO-L02) Unlock By ChimeraMã:@thanhnamPDAviet LYO-L02C718B124 Direct Unlock 7/18/2017 8:47:11 AM Direct Unlock 7/18/2017 8:43:12 AM Direct Unlock 7/18/2017 8:40:06 AM Direct Unlock 7/18/2017 8:33:34 AM Direct Unlock 7/18/2017 8:33:16 AM [Removing network lock...] This method will overwrite the factory recovery with a custom recovery (TWRP). In some cases, it will remain permanently installed on the phone. Are you sure you want to continue? Checking bootloader... Rebooting device to fastboot mode... Device found! bootloader status: unlocked Downloading TWRP recovery... Booting recovery... Please keep pressing down the volume up button while clicking OK below. Do not release the volume up button until recovery is booted. If a menu appears on the phone, select recovery mode. Removing SIM-lock... Finished successfully. Finished at local time: [07.18.17 15:48:39]
Huawei Elite (LYO-L02) LYO-L02C718B124 Khóa Sim Nhà Mạng Huawei Elite (LYO-L02) LYO-L02C718B124 Unlock Bootloader Huawei Elite (LYO-L02) LYO-L02C718B124 Unlock Network By ChimeraMã:Chimera Mobile Phone Utility version: 14.78.1602 @ 2017-08-19 Printing phone history Direct Unlock 8/19/2017 10:09:06 AM Direct Unlock 8/19/2017 10:07:52 AM Direct Unlock 8/19/2017 10:03:29 AM Direct Unlock 8/19/2017 10:01:21 AM Direct Unlock 8/19/2017 9:58:23 AM [Removing network lock...] This method will overwrite the factory recovery with a custom recovery (TWRP). In some cases, it will remain permanently installed on the phone. Are you sure you want to continue? Checking bootloader... Rebooting device to fastboot mode... Device found! bootloader status: unlocked Downloading TWRP recovery... Booting recovery... Please keep pressing down the volume up button while clicking OK below. Do not release the volume up button until recovery is booted. If a menu appears on the phone, select recovery mode. Removing SIM-lock... Finished successfully. Finished at local time: [08.19.17 17:13:39] WorkID: 25343647
