Lâu lâu lại thấy có anh em hỏi tool. Xin thưa em nó đây Down về, cài bình thường, cài thêm java ở đây http://javadl.sun.com/webapps/download/AutoDL?BundleId=107098 Chép file FW sony vào thư mục C:\Flashtool\Firmware Link Fshare: http://www.fshare.vn/file/KBKL148HHMHB Link Google drive: https://drive.google.com/file/d/0B80iGRqqPs2NbWFlbFhZQXY3UTA/edit?usp=sharing Driver flash interface sony : http://www.fshare.vn/file/V8887YZUXWIK 1 số máy dùng phím back + cắm cáp để về flash mode Máy nào không có phím back cứng thì cứ bấm volume (-) và cắm cáp để về flash mode (đèn led xanh lá là đã về flash mode)
chạy cây m2 nó báo vậy là sao anh 12/058/2015 21:58:11 - INFO - Device disconnected 12/058/2015 21:58:28 - INFO - Selected Bundle for Sony Xperia C (C2305). FW release : 16.0.B.2.6. Customization : World_Generic 12/058/2015 21:58:28 - INFO - Preparing files for flashing 12/058/2015 21:58:28 - INFO - Please connect your device into flashmode. 12/058/2015 21:58:42 - INFO - Device connected in flash mode 12/058/2015 21:58:42 - INFO - Opening device for R/W 12/058/2015 21:58:42 - INFO - Reading device information 12/058/2015 21:58:42 - INFO - Unable to read from phone after having opened it. 12/058/2015 21:58:42 - INFO - trying to continue anyway 12/058/2015 21:58:42 - INFO - Start Flashing 12/058/2015 21:58:42 - INFO - Processing loader.sin 12/058/2015 21:58:42 - INFO - Checking header 12/058/2015 21:58:42 - ERROR - Processing of loader.sin finished with errors. 12/058/2015 21:58:42 - INFO - Ending flash session 12/058/2015 21:58:42 - ERROR - Error in processHeader : Read error :31 : A device attached to the system is not functioning. 12/058/2015 21:58:42 - ERROR - Error flashing. Aborted 12/058/2015 21:58:43 - INFO - Device connected in flash mode
12/058/2015 21:58:28 - INFO - Selected Bundle for Sony Xperia C (C2305). FW release : 16.0.B.2.6. Customization : World_Generic sao chọn file Xperia C? C2305
cho mình hỏi phát con sony E1 D2005 chạy lỗi giờ mở nguồn k lên cắm vào máy tính vẫn nhận drive,nhưng tool báo lỗi For 2011 devices line, be sure you are not in MTP mode rồi đứng im k chạy giờ khắc phục lỗi này ra sao mod :-*
dow về mở ra báo lổi : c:/users/hungip/dowloads/sony_flashtool-0.9.18.1-windows.rar:Unexpected end of archive.
thank mod chia sẽ,tool này múc hết các dòng sony luôn hả Mod,cho em xin cách hướng dẫn chi tiết luôn đi. thank
cập nhật: flashtool-0.9.22.3-windows mới nhất cho ai cần https://drive.google.com/file/d/0B0smW6BbBawgWjJGMmhNZlR1NkU/view
có con e3 d2202 flash mãi mà không được, tình trạng treo logo đưa về flash mode mà không nhận cáp , không biết thiếu driver hay bị gì nửa
