Pangu vừa update tool trên trang chủ,AE có máy đang iOS 8.3 down về ngâm cứu :''' Pangu for iOS 8.3 - Jailbreak iOS 8.3 using Pangu iOS 8.3 Jailbreak Download Pangu (Latest Version) Download TaiG for Windows (Latest Version) Download PPJailbreak for Mac (Latest Version) Còn đây là tool TaiG http://apt.taig.com/installer/en/TaiGJBreak_EN_2000.zip Thông báo AE lả nếu JB bằng TaiG treo 20% thì bật màn hình,nhấn slide to unlock cho nó vô màn hình chính là ok Pangu for iOS 8.3 Is jailbreak really available for iOS 8.3? As you all know Pangu jailbreak tool can be used to jailbreak many iOS versions such as iOS 8, iOS 8.1 and some of its minor versions. But there is no jailbreak tool released yet for iOS 8.3 jailbreak. But there are tools for iOS 8.3 to install Cydia on devices which are running iOS 8.3. Semi Jailbreak The only possible way to jailbreak iOS 8.3 devices is Semi Jailbreak. Try searching "Semi Jailbreak" on Google to fnd out semi jailbreak for iOS 8.3 Google +25 99 27 5 44 49.9K When will Pangu release iOS 8.3 jailbreak tool According to Apple, it closed the security hole which disclosed early by Pangu and Pangu confirmed that they cannot use the same technology to jailbreak iOS 8.3. So developers at Pangu is still trying to disclose a security hole to get into Apple’s file system and extract the hidden features and functionalities. Once Pangu complete this process, they will release the jailbreak tool “Pangu for iOS 8.3” It is really happy to let you know that Pangu has halfway done its jailbreak process and the jailbreak tool will be released within a few more weeks. According to Pangu they will proudly announce it during next few weeks. Cydia on iOS 8.3 Download Pangu 8.3 To download pangu 8.3 jailbreak tool, you can visit to semi jailbreak official site using your iOS based device. It will first get remote packages and semi jailbreak your iOS based device and install semi jailbreak app on your device. Later it will upgrade to semi jailbreak cydia instead semi jailbreak app. Pangu for iOS 8.3.1 and 8.3.2 Pangu iOS 8.3 jailbreak tool can be used to jailbreak iOS 8.3.1 and iOS 8.3.2 versions as well. Since 8.1.2 and 8.1.3 are minor versions of iOS 8.3, the same tool can be used with those minor versions, but not other major versions such as iOS 8.4. Update : Recently i0nic jailbroken iOS 8.4 beta 1 and we hope i0n1c will release their jailbreak tool for iOS 8.4 Pangu 8.3 Jailbreak Developers The jailbreak community summit held at China, Pangu developers and all other jailbreak developers agreed to work together to find a jailbreak solution for iOS 8.3. The set of small developers called as semi jailbreak team released Semi-Jailbreak for iOS 8.3. Also there are some other set of developers are developed some other awesome tools for iOS 8.3 jailbreak and none of them really perform fully jailbreak for iOS 8.3. But those tools can be used to perform some of the operations such as installing themes, installing free applications and games The most popular one among those applications are “Semi-Jailbreak” and they ask for a donation to develop their jailbreak tool. It is really worth to give it a try by donating a few bucks. - See more at: http://pangu8.com/pangu83.html#sthash.TJjEev9w.dpuf
Cũng mới nhận được SMS TaiG từ twitter.com >> 6:10 PM - 23 Jun 2015 · Details Link tải về: http://taig.com/
Cái này hình như mới chỉ là Semi JB thôi chứ ko phải JB hẳn...ae nào thik dọc thì cứ làm...còn ko thì đợi 1 thời gian JB hoàn chỉnh làm luôn vì theo thông tin từ Pangu thì khi Apple ra FW mới (8.4 hay ios 9 chưa biết đc) sẽ có bản JB hoàn thiện cho 8.3 luôn
Em đang dính một em bị mất thanh volume. nghe tin jb có là load về chiến thử. gọi khách ra jb cứ treo vậy. buồn cho đội đồng tháp
