thay emmc samsung g313hz ace chi em nào thay rồi giúp em chết emmc em tháy emmc này giống thay vào nạp file dum rồi còn làm gì nữa không ace em chưa làm gì hết chi mới thấy con emmc này bên lumia giống nen lấy lên hỏi ace cánh làm
ace xem log Z3X EasyJtag Software ver. 2.5.0.7 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0F00A01C05873C69, ,FW Ver.: 01.58 CMD Pullup Level:3248 mV CMD Active Level:3176 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004E35585A4D42019E3FD6F691F0 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2014 Rev.0x1 EMMC NAME: N5XZMB , S/N: 2654983926 EMMC NAME (HEX): 4E35585A4D4200 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: N5XZMB_2654983926_20170510_0651.extcsd Done.
chac bi mian rồi emmc cũ EMMC CID : 1501004E35585A4D4203BBF0B4B73210 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 03/2015 Rev.0x3 EMMC NAME: N5XZMB , S/N: 3153114295 EMMC NAME (HEX): 4E35585A4D4200 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: N5XZMB_3153114295_20170510_0654.extcsd Done.
