nhận oppo chết ổ cứng, lấy ổ cứng samsung thay qua check ra log thế này, anh em giúp có đc ko HiPower mode is OFF CMD Pullup Level: 2052 mV CMD Active Level: 2433 mV EMMC Device Information : EMMC CID: 1501004B4A5330304D0AD2E7CCFB11BC EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG EMMC NAME: KJS00M , S/N: D2E7CCFB , rev. 0A EMMC NAME (HEX): 4B4A5330304D EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Backup saved: KJS00M_D2E7CCFB_20170317_063743.extcsd EMMC Init completed.
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) phân vùng lại 2 dòng này thành 4096kb xong đóng ổ cứng vào nạp rom loại 4GHI là ok
Nhìn hình tự so sánh nhé. Nhớ đổi boot và RPMB cho đúng thông số nhé. Cách đổi cid hay boot thì sear 4r hay gg tìm hiểu thêm. Đây là log info r827:
---------- eMMC Device Information ---------- EMMC CID : 1501004B4A5330304D0AD2E7CCFB11BC EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: KJS00M , S/N: 3538406651 EMMC NAME (HEX): 4B4A5330304D00 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: KJS00M_3538406651_20170317_0653.extcsd EMMC cũ chết mất, check ko ra được. nhà có main xác samsung lấy cứng đóng qua check ra vậy nhưng chạy pm báo lỗi, nhờ anh em chuyên EMMC xem giúp thay qua chạy có được ko, cảm ơn nhiều
đưa cái nay :: RPMB (Replay Protected Memory Block) Capacity: 128 kB RPMB (Replay Protected Memory Block) Capacity: 4096kb
