Tecno WX4 Pro Remove Lock Screen - FRP By CM2
Thảo luận trong 'SỬA CHỮA – UNLOCK – XÓA iCLOUD – FILE – ROM - TOOL' bắt đầu bởi Mobileservices, 10/7/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
    Mobileservices (Offline)
    Sửa bài viết để cập nhật
    (VNĐ)
    0966833711 Click để xem
    https://www.facebook.com/thanhnamPDAviet.VN (Click để xem bản đồ)
    Gửi 10/7/18, 0 Trả lời, 436 Đọc
  1. 10/7/18 lúc 08:27
    Mobileservices
    Mobileservices
    Tecno WX4 Pro Remove Lock Screen - FRP Done
    Mã:
    Card found : S/N : 80097B3B , v0136
    Chinese Miracle II  [MTK module] v 1.58
    Operation : Format FileSystem [ v1.58 ]
    1. Power Off Phone , Remove battery , Insert back
    2. Insert USB cable. In some cases require hold BootKey
    Wait for phone...
    Phone found! [ 18 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6737
    BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
    BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x00000000
    BromVer   : 0x0005
    BLVersion : 0x00FE
    PreLoader : NOT Active [ Erased ]
    BootLdrSS : NORMAL with PRELOADER
    Processing DA stage
    DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x93
    NAND Flash : NOT INSTALLED
    eMMC Flash : 510001154D333145B95F0D42ED29A5D8
    Initialize Memory ...
    DRAM configured from IDB!
    DRAM initialize passed!
    DRAM size : 0x80000000
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0x15 , OEM : 0100
    [eMMC] : FLASH_INF : [SAMSUNG] , BM31E
    [eMMC] : FLASH_CID : 150100514531334D420D5FB9D8A544ED
    [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000
    [eMMC] : FLASH_LEN : 0x00000003A3E00000
    [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
    DEV RID	: 0xF85F4F29A946CF2AA43F98724233B67C
    INT RAM	: 0x00020000
    EXT RAM	: 0x80000000 [2 GiB]
    BOOT TYPE  : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    Clear FRP ( Google Reset Protection )
    Clear Ok!
    Done!
    Elapsed: 00:00:35
    Reconnect Power/Cable!
Trạng thái chủ đề:
