sữa box easy jag
Thảo luận trong 'THIẾT BỊ HỖ TRỢ SỬA CHỮA.' bắt đầu bởi honglinh_daklak, 1/12/18.
  1. 1/12/18 lúc 15:23
    honglinh_daklak
    honglinh_daklak
    như tiêu đề em mua box lâu rồi mà tin tưởng không kiểm tra giờ hoi thi ko tra loi
    em cài ok mà chạy toàn bị lỗi cần anh em giúp với
    Setting frequence to 1 Mhz
    CMD Pullup Level: 2062 mV
    CMD Active Level: 3011 mV
    EMMC Device Information :
    EMMC CID: 90014A483447326111013624A843B2DC
    EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
    EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2a , HEX: 483447326100 , S/N: 3624A843 , rev. 0x01
    EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2015
    EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    Extended CSD Information :
    Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
    Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
    Boot Bus Config: 0x00 , width 1bit
    H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
    Supported partition features [PARTITIONING_SUPPORT]: 0x07
    Device supports partitioning features
    Device can have enhanced technological features in partitions and user data area
    Device can have extended partitions attribute
    Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
    Backup saved: H4G2a_3624A843_20181004_152409.extcsd
    EMMC Init completed.
    Operation: Changing GP sizes (final write) ...
    GP1 size: 0 MB , WR_REL: 1 , ENH 1
    GP2 size: 0 MB , WR_REL: 1 , ENH 1
    GP3 size: 0 MB , WR_REL: 1 , ENH 1
    GP4 size: 0 MB , WR_REL: 1 , ENH 1
    HW_PART error. Reason: Zero sizes
    đã tết nhiều may mà toàn lời như vậy
    anh em giúp tây với sẽ có hậu tạ xứng đáng vì mua lô oppo mà ngâm lâu nay rồi
  2. 1/12/18 lúc 16:14
    honglinh_daklak
    honglinh_daklak
    uppppppppppppppppppppp
  3. 1/12/18 lúc 17:34
    Tiem_IC
    Tiem_IC
    inbox zalo 0984.083747 .
  4. 1/12/18 lúc 17:48
    hungquyendtdd
    hungquyendtdd
    DDc chưa bạn?
  5. 1/12/18 lúc 18:30
    bigbaboi
    bigbaboi
    log này bt mà ổ skynis set dc 1 lần lấy đâu dc lần nữa mà set
  6. 1/12/18 lúc 21:02
    No-iMEi
    No-iMEi
    bình thường mà ta, lấy ổ KMK7x đổi fimware rồi mở tool jtagPlus lên nạp thử xem . có thể là do thớt chưa biết cách sài box này
    honglinh_daklak thích bài này.
  7. 2/12/18 lúc 10:30
    honglinh_daklak
    honglinh_daklak
    chhua anh oi
  8. 2/12/18 lúc 12:11
    Bảo@Minh
    Bảo@Minh
    đã info được như này là box bình thường còn lại là do mình thôi .chịu khó ngâm cứu và học hỏi nhiều sẽ làm được .đừng đổ lỗi do box
  9. 2/12/18 lúc 13:21
    hungquyendtdd
    hungquyendtdd
    Bạn cài lại win hoặc đổi máy tính khác xem nếu chắc chắn câu kéo chuẩn rồi
