sony SOL11 unlock cần giúp!
Thảo luận trong 'SONY ANDROID' bắt đầu bởi annguyen1310, 16/8/18.
  1. 16/8/18 lúc 09:57
    annguyen1310
    annguyen1310
    em nhận unlock con sony SOL11 mà sao toàn FAILED. em nghe nói box phải active S1 (unlock free X10) không biết phải ko.
    log em unlock:
    SIGNED MODE (USING SERVER)
    ALTERNATIVE SECURITY BYPASS ENABLED
    CFG:110010000000
    DETACH USB CABLE FROM PHONE
    REMOVE BATTERY FROM PHONE
    ATTACH TESTPOINT
    PRESS "READY", THEN ATTACH USB CABLE TO PHONE
    PROCESSING ...
    REMOVE TESTPOINT NOW, THEN PRESS "READY"
    PLEASE ATTACH TURNED OFF PHONE NOW
    PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
    RUNNING S1_LOADER VER "R4A069"
    EROM_AID : 0001
    LOADER_AID : 0001
    HWCONF_AID : 0001
    ACTIVE_LOADER_AID : 0001
    DEVICE ID: 96FE413D8073B87D1EE6FFD4E78F014D0B8401E4
    FLASH ID: "0098/00B3"
    LOADER VERSION: "r4A069"
    PHONE IMEI : 99000063203206
    Checking for signature ...
    Waiting for calculation process ...
    request denied.
    signature calculation not done,err: 144
    Unlock FAILED
    Elapsed: 42 secs.
    log check info box
    RUNNING v 1.1289/01.10/UNI
    CARD SERIAL 00157875
    CFG:000000000000
    short credits consumption list :
    Services OFFLINE
    S1 v1,v2,S1 OPEN AID 004,FLASHMODE activation
    Services ONLINE
    A1 phones, CSCA unlock/repair 03 credits
    A2 phones, CSCA unlock/repair 03 credits
    S1 OPEN, CSCA unlock/repair 03 credits
    W100,W150 unlock codes 01 credits
    S1 QSD8250,MSM7227,MSM8255 alternative bypass unlock/repair 01 credits
    ST21,ST21i2,ST23,ST26,C150x,C160x alternative bypass unlock 01 credits
    You CAN NOT unlock next phones, when S1 services offline:
    u1/u5/u8 with loader AID 004,
    LoCosto,Neptune-based phones with loader AID 004,
    LoCosto,Neptune-based phones with damaged security zone,
    w100,w150 full unlock,ck13,ck15,wt13,
    any SONY phone, released from 2012 year,except
    ST21,ST21i2,ST23,ST26,C150x,C160x phones
    S1 QSD8250,MSM7227,MSM8255 alternative bypass STANDALONE activation 10 credits
    ST21,ST21i2,ST23,ST26,C150x,C160x alternative bypass unlock/repair FREE, if you have this activation
    current updater version: 0.95
    current setool2 version: 1.1433
    request denied.
    CARD COUNTERS: FLASH 458, UNLOCK 105
    Elapsed: 2 secs.
    thanks anh em rất nhiều
  2. 16/8/18 lúc 10:47
    NhutGsm
    NhutGsm
    check 1,2,5,11 rồi unlock lại thử
    annguyen1310 thích bài này.
  3. 16/8/18 lúc 10:58
    annguyen1310
    annguyen1310
    vẩn vậy anh.test piont ok hết mà vận failed
  4. 16/8/18 lúc 11:37
    chicong2008
    chicong2008
    chọn s002 thử cái anh
  5. 16/8/18 lúc 11:51
    annguyen1310
    annguyen1310
    không thấy đời máy ta
  6. 16/8/18 lúc 14:13
    transy
    Super Moderator
    transy
    Có thể do testpoint chưa được, chưa đúng thời điểm, dây TP sai, chứ model này unlock bình thường.
    Testpoint chọn theo hình model so02c, trong thư mục docs của setool. Trong settings check 1,2,5 .
  7. 16/8/18 lúc 16:16
    Cường dola
    Cường dola
    Con này unlock tốn credits nha bạn
