nhận con sky a810k mất boot cho vào riff ripe thì lỗi như bên dưới anh em nào có phương an nào ko giúp mình với thank all Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 2 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (KYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (KYL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000
