Sky A810s mất boot Repair ok
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi GiabinhGSM, 17/6/13.
  1. 17/6/13 lúc 17:21
    GiabinhGSM
    GiabinhGSM
    Sky A810s Máy mang vào trong tình trạng mất nguồn Repair Phát lên luôn :mad:
    Open serial port...OK
    Connecting to the RIFF Box...OK
    Firmware Version: 1.35, JTAG Manager Version: 1.48
    Selected Resurrector: [Pantech A810S V1.0.4816.62650]
    Connecting to the dead body...OK
    Detected dead body ID: 0x106A10E1 - CORRECT!
    Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK
    Adaptive Clocking RTCK Sampling is: [Sample at MAX]
    Resurrection sequence started.
    Establish communication with the phone...OK
    Initiali**** internal hardware configuration...OK
    Uploading resurrector data into memory...OK
    Starting communication with resurrector...OK
    Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (KYL00M, 0x0003AB400000 Bytes = 14.68 GB)
    Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (KYL00M, 0x000000080000 Bytes = 0.50 MB)
    Flashing the dead body...OK
    Resurrection complete!
