SamSung On7 G6000 xóa samsung account ok done by octoplus
Thảo luận trong 'SỬA CHỮA – UNLOCK – XÓA iCLOUD – FILE – ROM - TOOL' bắt đầu bởi QuangSangGSM, 9/7/18.
    QuangSangGSM (Offline)
    Sửa bài viết để cập nhật
    (VNĐ)
    090.888.9267 Click để xem
    Gửi 9/7/18, 3 Trả lời, 1,009 Đọc
  1. 9/7/18 lúc 15:57
    QuangSangGSM
    QuangSangGSM
    Mã:
    NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service.
    Connecting to server...
    Connecting to server...Ok!
    Checking resource files...
    Resource files already downloaded.
    Please put the phone into Download Mode and connect USB cable.
    To put SM-G6000 into Download Mode, You have to perform the following steps:
    1. Reconnect the battery.
    2. Press and hold "Volume-" + "Home" + "Power ON" keys.
    3. When phone turns on, press "Volume+" key.
    Waiting for phone...
    Firmware write started.
    Writing Custom section...
    Custom section has been written successfully.
    FRP lock is successfully reseted!
    Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset"
    Performed by 2.6.9 Software version.
    Capture21-06-2018-5.36.13 CH22-06-2018-2.01.23 CH09-07-2018-2.13.06 CH.
  2. 9/7/18 lúc 16:19
    Tuan Pham
    Tuan Pham
    done nhưng ko mở đc OEM và reset bị dính lại
  3. 9/7/18 lúc 16:45
    Mobileservices
    Mobileservices
    bộ nhớ đầy,hanset thì dính lại. :D
    Giải pháp là đưa 2 giá cho khách chọn
  4. 9/7/18 lúc 16:46
    QuangSangGSM
    QuangSangGSM
    do máy khách ở xa thôi chứ cầm tận tay thì làm ok 5p ah
