Samsung Galaxy S7 edge SM-G935U 6.0.1 Reset FRP Ok !
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi taki7610, 21/12/16.
  1. 21/12/16 lúc 10:01
    taki7610
    taki7610
    Mã:
    To connect SCL24 phone you have to perform the following steps:
    1. Disconnect USB cable from phone.
    2. Go to Menu->Settings->More->About Device.
    3.Tap on "Build number" 7 times to enable developer options.
    4. Go to Menu->Settings->More->Developer options.
    5. Turn on "USB Debugging" option.
    6. Go to dial window.
    7. Enter "*#0808#" number.
    8. Select "DM+Modem+ADB".
    9. Press Home button.
    10. Restart phone.
    11. Press "Read Info" in software.
    To connect SM-G935U phone you have to perform the following steps:
    Platform: Samsung Android
    Selected port: COM17
    Selected model: SM-G935U
    Connecting to server...
    Connecting to server...Ok!
    Checking resource files...
    Downloading resources...
    All necessary resource files have been downloaded successfully.
    Please put the phone into Download Mode and connect USB cable.
    To put SM-G935U into Download Mode, You have to perform the following steps:
    1. Reconnect the battery.
    2. Press and hold "Volume-" + "Home" + "Power ON" keys.
    3. When phone turns on, press "Volume+" key.
    Waiting for phone...
    Firmware write started.
    Writing Boot section...
    Boot section has been written successfully.
    Searching for a phone. Please wait...
    Phone found.
    Resetting FRP lock..
    Performed by 2.4.6 Software version.
    Searching for a phone (waiting for ADB device)...
    Reading info...
    Detected phone model: SM-G935U
    Firmware compiled date: Fri Sep  9 20:30:48 KST 2016
    PDA version: G935UUEU4API3
    CSC version: G935UOYM4API3
    SW version: G935UUEU4API3
    Phone SN: RF8H61JNP8Z
    Android version: 6.0.1 (MMB29M)
    Sales code: XAA
    Country: USA
    HW platform: msm8996
    HW Chip: MSM8996
    HW Modem: MSM8996
    Security patch level: 2016-09-01
    Codename: hero2qlteue
    FRP lock is successfully reseted!
    Goto "Backup and reset" and make "Factory data reset"
    [​IMG][​IMG][​IMG][​IMG]
    duytien76 thích bài này.
  2. 6/5/18 lúc 16:12
    duytien76
    duytien76
    a ơi có file s7 edge g935 6.0.1 ko cho em xin với em cung đang cần . cảm ơn
  3. 6/5/18 lúc 17:44
    TrongNguyen132
    TrongNguyen132
