Root Sony Z5 7.1.1
Thảo luận trong 'SONY ANDROID' bắt đầu bởi Tuấn Anh iStore, 6/3/18.
  1. 6/3/18 lúc 00:25
    Tuấn Anh iStore
    Tuấn Anh iStore
    Vừa lượn XDA kiếm được bài này. Toàn tiếng A, nhưng các bước tương tự chạy Rom gốc thôi ạ
    Hi xda users,
    I am very pleased to present LATEST NOUGAT FTFs Google Drive Mirror, Patched Kernels and TWRP .
    I spend lots of time and bandwidth for you, so please hit
    Thanks [​IMG] button and comment below..
    Bootloader LOCKED Devices
    -Just follow 1 to 14 steps
    Bootloader UN-LOCKED Devices
    -Just follow 1 to 30 steps
    Google Drive Mirror File List
    -7.1.1 (32.4.A.1.54) FTFs (E6603, E6633, E6653, E6683)
    -Patched Kernels
    -TWRP 3.1.1.0 thanks to @kv123
    -ROOT Methods (SuperSU, phh and Magisk)
    -Flashtool, Flashtool-drivers (0.9.23.2)
    http://123link.pw/yH51RZv
    Click this for List view
    Patched Kernel Specifications
    • sony-ric
    • dm-verity
    • drm-fix
    • busybox-1.26.2
    • fully /system read&write access
    If r/w didn't work for you, please do that. It will be fixed.
    1.Install Termux on Play Store.
    2.Write "su" command and give root access.
    3.Then write this
    Code:
    echo 0 > /sys/kernel/security/sony_ric/enable
    4.Lastly write this
    Code:
    busybox mount -o rw,remount,rw /system
    Done [​IMG]
    Step by Step Installation
    Summary
    • Install Flashtool & Drivers
    • Flash FTF
    • Flash Patched Kernel & TWRP
    • Flash ROOT
    Detailed
    1-) Install flashtool-0.9.23.1-windows.exe
    2-) Copy x10flasher.jar file into "C:\Flashtool", open Flashtool wait until process done then quit program.
    3-) Disable "Driver Signature Verification"
    Windows 7 : Tap F8 while booting and select required option
    Windows 8, 8.1, 10 : Read This Instructions
    4-) Install Flashtool-drivers.exe (flashmode, fastboot, z5)
    5-) Copy FTF file into "C:\Users\YOUR PC NAME\.flashTool\firmwares"
    6-) Backup your Photos & Videos & Musics etc. on Internal Memory to SDCard or PC
    7-) Shutdown your phone
    :cool: Open Flashtool (x32 suggested)
    9-) Click Flash button (top left) then Ok button, select FTF on left side
    10-) Select ALL wipe options, no NEED Misc TA for every flash (SKIP this, if you want to just UPDATE and keep data)
    11-) Click Flash button, wait 1 minute (you will see an info)
    12-) Push VOLUME DOWN button, then connect phone to pc (green led)
    13-) When flashing done, disconnect and boot-up your phone, complete setup wizard (required)
    14-) If you want to use Patched Kernel or ROOT your phone then continue otherwise flashing FTF process done
    You have to BL Unlocked device to continue..
    15-) Shutdown your phone
    16-) Push VOLUME UP button, then connect phone to pc (blue led)
    17-) Copy 32.4.A.1.54_E66XX.img and twrp_recovery.img file into "C:\Flashtool\x10flasher_lib"
    1:cool: Open "C:\Flashtool\x10flasher_lib" folder
    19-) Then press LEFT SHIFT and click mouse right button into this folder
    20-) Then press Open command window here option
    21-) Then type this code into cmd (xx your model)
    Code:
    fastboot.exe flash boot 32.4.A.1.54_E66xx.img
    fastboot.exe flash recovery twrp_recovery.img
    22-) Disconnect your phone and boot-up (required)
    23-) If you want to ROOT your phone then continue otherwise flashing Patched Kernel process done
    24-) Put ROOT files into Internal Memory
    SuperSU - Most common root solution
    phh's Superuser - I think best root solution
    Magisk - Module solution & It has built-in phh root solution
    25-) Boot-up your phone into TWRP
    -TWRP : Volume DOWN + Power
    26-) If you want to use SuperSU, just flash zip and reboot
    27-) If you want to use phh, just flash zip and reboot You have to install "me.phh.superuser.apk"
    Latest Magisk
    Latest Magisk Uninstaller
    2:cool: If you want to use SuperSU & Magisk, flash SuperSU first then Magisk then Install Magisk Manager
    29-) If you want to use Magisk, flash latest Magisk then Install Magisk Manager
    30-) Have fun [​IMG]
    You can delete ALL System Apps with System App Remover ROOT APP
