Rom các dòng HK phone
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi hoangthanhmobil, 30/5/13.
  1. 30/5/13 lúc 10:52
    hoangthanhmobil
    hoangthanhmobil
    1. HKphone 4S-3G có reset giao diện ios5
    http://www.mediafire.com/?crf7bwu4j4soosz
    2. HKphone 4S-3G có reset giao diện ios6
    http://www.mediafire.com/?czb7n7iunuwtzkh
    3. Hkphone 4S-3G no reset
    http://www.mediafire.com/?wboehtb99mb7ao9
    4. Hkphone 4s Retina
    Rom gốc : http://www.mediafire.com/?8lm335u6dowbqhu
    Rom ver 1 : http://www.mediafire.com/download.php?2ytca681bojyts6
    Rom Ver 2.1 : http://www.mediafire.com/?31u7j830fb1uk2e
    5. HKphone 4S retina Pro
    https://hkphone-2013.googlecode.com/files/[ROM]4S-Pro-IOS 6-10-3-2013.zip
    6. HKphone H7-3G
    http://android-h7-3g.googlecode. ... date-haiduongbk.zip
    Driver: http://android-h8-3g.googlecode.com/files/driver-full 6573.rar
    Công cụ Flash Tool: http://android-h8-3g.googlecode.com/files/SP_Flash_Tool_v2.1134.00.7z
    Link ROM Flash tool: http://android-h7-3g.googlecode. ... v5.5-haiduongbk.rar
    7. HKphone X8-3G
    http://android-x8-3g.googlecode.com/files/MrTB_FM.zip
    http://android-x8-3g.googlecode.com/files/MrTB_v10.zip
    http://android-x8-3g.googlecode.com/files/MrTB_v9.zip
    http://android-x8-3g.googlecode.com/files/MrTB_v8_Plus.zip
    http://android-x8-3g.googlecode.com/files/MrTB_Mix_H8.zip
    Rom gốc: http://www.mediafire.com/?ffrd0jy5tj0l5p5
    8. HKphone H8-3G
    http://android-h8-3g.googlecode.com/files/H8-3G-2.3.6-v7.8-haiduongbk.zip
    Công cụ Flash tool: http://android-h8-3g.googlecode.com/files/SP_Flash_Tool_v2.1134.00.7z
    Link ROM Flash tool: http://android-h8-3g.googlecode. ... v7.8-haiduongbk.rar
    Rom gốc: http://code.google.com/p/android-h8-3g/downloads/detail?name=..H8-3G HKPHONE.. 20120221.zip&can=2&q=
    9. HKphone Revo HD
    SGS3- 4.0.4 - 2-2-2013-final
    P1: http://revo-hd.googlecode.com/files/[update]Revo HD 4.0.4 -SGS3 (2-2-2013).zip.001
    P2: http://revo-hd.googlecode.com/files/[update]Revo HD 4.0.4 -SGS3 (2-2-2013).zip.002
    Rom gốc:
    P1: http://revo-hd.googlecode.com/files/Revo HD 4.0.3 -original (1-10-2012).rar.001
    P2: http://revo-hd.googlecode.com/files/Revo HD 4.0.3 -original (1-10-2012).rar.002
    P3: http://revo-hd.googlecode.com/files/Revo HD 4.0.3 -original (1-10-2012).rar.003
    10. HKphone Revo S:
    Rom gốc up qua flashtool.
    http://revo-s.googlecode.com/files/REVO S -original (2-11-2012).rar.001
    http://revo-s.googlecode.com/files/REVO S -original (2-11-2012).rar.002
    http://revo-s.googlecode.com/files/REVO S -original (2-11-2012).rar.003
    Link Flash tool: http://revo-hd.googlecode.com/files/Flashtool_4.0.rar
    Link Driver: http://android-hkphone-revo.goog ... _PATCHED%20v4.0.rar
    Rom gốc up qua recovery.
    http://revo-s.googlecode.com/files/REVO S -original (2-11-2012)-update.zip.001
    http://revo-s.googlecode.com/files/REVO S -original (2-11-2012)-update.zip.002
    11: HKphone Revo:
    Bản 4.0.4 - SGS3 -Special 4 - 2 - 2013
    http://hkphone-revo.googlecode.com/files/REVO 4.0.4-SGS3 - 4-2-2013.rar.001
    http://hkphone-revo.googlecode.com/files/REVO 4.0.4-SGS3 - 4-2-2013.rar.002
    có thể lin sẻ dẩn đến các wep khác, nhiều quá kg đủ thời gian kiểm tra, mod có đi qua thì xoá dùm, vì 1 số file hiếm nhầm giúp đở a,e..Cách uprom thì a,e nào test ok thì chia sẻ cho a,e. Thân
  2. 30/7/13 lúc 16:21
    nhan-gsm
    nhan-gsm
    một số link die rồi bạn ơi, có thời gian fix lại dùm
  3. 31/7/13 lúc 11:11
    hùng chợ lớn™
    hùng chợ lớn™
    cho xin rom revo SII HD và hướng dẫn đi bác đang bị con nầy mà chưa biết rành Android
  4. 31/7/13 lúc 11:32
    kiên3G_GSM
    kiên3G_GSM
    thanks share có thời gian test hết món này là ok.
  5. 17/9/13 lúc 14:34
    smartphone new
    smartphone new
  6. 17/9/13 lúc 14:49
    traiit
    traiit
    quánh dấu khi nào có kèo múc
  7. 8/11/13 lúc 10:44
    kienthuan
    kienthuan
    Hkphone revo hd4 thì load file nào anh........
  8. 11/1/14 lúc 11:34
    chaubathong1
    chaubathong1
    cho mình xin rom gốc hkphone revo lead
  9. 19/9/15 lúc 17:31
    tanhamobile
    tanhamobile
    a có rom stock hkphone RACER AIR cho mình xin voi
  10. 19/9/15 lúc 18:19
    AnhDuy mobile
    AnhDuy mobile
    củng hay , hkphone đả ngủ , nhưng dư âm vẩn còn , nhiầu khi cần tìm ko ra . thank :D
  11. 18/10/15 lúc 17:38
    baolinh_82
    baolinh_82
    bác nào có rom HKphone revo max 8 cho em xin với...cả tool flash luôn.
  12. 28/10/15 lúc 14:29
    bvt hp
    bvt hp
    anh em ai có bản rom hkphon revo s2 chạy chip mt 6628 cho mình xin nhé
  13. 4/12/15 lúc 10:24
    BinhThuan_VF
    BinhThuan_VF
    anh oi co rom SGS5 không ạ! .
  14. 18/9/16 lúc 03:19
    khanhbang_vo
    khanhbang_vo
    hí hí hí ....nay chơi lớn anh ka ka ka ....rom HK em phụ anh trai nha, anh nào cần rom HKphone hú em bao....em trong đó ra mà...ka ka ka
    Nhất Chính thích bài này.
  15. 13/3/17 lúc 22:40
    Nhất Chính
    Nhất Chính
    Bác cho em xin rom của HKPHONE RACER INNO với ạ.
  16. 14/3/17 lúc 07:13
    B.Thuận_GSM
    B.Thuận_GSM
  17. 21/3/17 lúc 10:04
    intelli
    intelli
    cho mình xin rom gốc của hk phone revo lead 8 và hk phone revo max nhé ( revo max, ko phải max 8 nhé)
    cám ơn các bạn rất nhiều
  18. 21/3/17 lúc 10:31
    B.Thuận_GSM
    B.Thuận_GSM
    intelli thích bài này.
  19. 21/3/17 lúc 14:22
    intelli
    intelli
    Cám ơn bạn
    Rom đó mình úp vào lead 8 thì nó lại bị lỗi ko bắt được wifi, nghĩa là nó ko hiển thị tên wifi, dù đặt điện thoại bên cạnh wifi nó cũng ko hiển thị
    mình search google có bạn hướng dẫn là đổi file wpa_suplicant gì đó mà mình ko có file đó.
    Bạn hướng dãn mình cách khắc phục nhe`
    còn bản revo max thì mình cũng ko rõ 2012 hay 2013
    bạn cứ gửi 2 bản đi, mình úp từng cái, cái nào được thì xài
    trước có úp 1 bản cho max 8 mà nó cũng bị lỗi wifi
  20. 24/10/17 lúc 12:44
    phanlam
    phanlam
    cho mình xin rom gốc của HK Phone Revo Lead . cảm ó́́́
  21. 24/10/17 lúc 15:03
    dienthoaicujbap
    dienthoaicujbap
    Ai có cảm ứng hk phone revo hd4
    Hú mình luôn nhé thanks
