RIFF JTAG Manager v1.58 - Support Repair eMMC via ISP Connection - Lại tốn $$ rồi :D
Thảo luận trong 'THIẾT BỊ HỖ TRỢ SỬA CHỮA.' bắt đầu bởi Star, 16/4/16.
  1. 16/4/16 lúc 14:33
    Star
    Super Moderator
    Star
    Hello,
    Here is JTAG Manager v1.58 with ISP/Direct eMMC support.
    To use it, please prepare Your RIFF Box installation folder:
    - Rename JTAG Manager v1.56 so You can continue using it if Your account is expired
    - Backup "Useful plugins" folder content because old plugins are incompatible with new Exe, and old exe is incompatible with new plugins. [​IMG]
    - Start v1.58 exe and download license (If Your account is not expired)
    - Update Box firmware to v1.38
    - Download new plugins
    Old server will be online for some weeks, so users who don't need or cannot acquire new license can get license if they need it.
    There will be more info in short time.
    JTAG Manager 1.58
    - added direct eMMC Access Interface on the RIFFBOX RJ-45 port (check pinout picture for CMD, CLK, DAT0, etc pins positions).
    - added eMMC/SD Access page for Read/Write operations on eMMC/SD card via direct interface
    - added eMMC/SD Advanced dialog which allows to perform advanced operations with eMMC/SD cards
    (reading info, browsing through OCR, CID, CSD (and EXT_CSD for eMMC only) registers' fields, edit separate fields and writting back to card, reading/writting eMMC card's MCU's internal firmware, etc)
    - added convenient information presentation for specific eMMC chips: pinouts for testpoints, manuals how to use testpoints to resurrect dead eMMC, etc). These INFO files (*.riffinfo) are stored in JTAG Manager's Documents folder and can be downloaded via generic <Check for Updates> operation.
    - added eMMC Firmware Update option
    - added eMMC Firmware Reading option (firmware is stored in *.riffemmcfw format)
    For firmware read need to select chip from the list
    - *.riffemmcfw eMMC firmware files are now used by RIFF for firmware updates (plain binary files are supported too)
    - added elapsed time info for eMMC firmware update stages
    - added eMMC Testpoint info displaying (info files must be downloaded from support and are located in the JTAG Manager's 'Documents' folder.
    - added CMD42 Lock/Unlock functionality for eMMC. User can set/change/remove password to protect/unprotect (lock/unclock) the User Area Partition
    - added the User Area Partition Forced Erase to erase Locked User Area Partition and to reset Device lock/unlock state and password (CMD42's consequences)
    - added Samsung Factory Erase which erases and re-formats the Samsung eMMC chips.
    - fixed bug displaying wrong SD card size for cards capacity less than 2GB
    - few small improvements and bug fixes
    Firmware 1.38
    - added direct eMMC Access Interface functionality
    - improved one thing in the emmc communication
    - added the CMD42 Lock/Unlock/Pasword reset features
    - added Forced erase of locked User Area Partition
    - added Samsung eMMC Factory Formwat
    - fixed bug for SD card support
    - eMMC firmware update feature added
    New Version Download here : RIFF JTAG Manager v1.58
