repair lumia 900
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi minhtanbt, 3/2/15.
  1. 3/2/15 lúc 16:48
    minhtanbt
    minhtanbt
    ae xem có phải lỗi ổ cứng không ,câu kéo không biết có bị chạm gì không nửa :D
    eMMC Test Point Connection Module
    1. DO NOT USE THE PHONE"S BATTERY
    2. Connect the Soldered TP Connections to ATF Box
    3. Disconnect the USB Cable and Wait until the
    the ATF Software will tell you to Connect the USB.
    Interface Reset OK!
    eMMC Access Type: SECTOR MODE
    eMMC Supported Voltage Range:
    3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
    3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
    CID : FE014E4D4D4331364727107B99A3
    CSD : D04F01320F5903FFFFFFFFFF8A400001
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : USER AREA
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
    RESET BUS WIDTH : ENABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 3584 KB
    HC ERASE GROUP SIZE: 8192 KB
    USER AREA SIZE : 15636365312 BYTES
    BOOT PARTITION SIZE: 128 KB
    RPMB PARTITION SIZE: 128 KB
    Lumia 900 Detected
    eMMC Device Information
    Manufacturer ID: FE
    Device Type : Embedded BGA
    Application ID : 4E
    Product Name : MMC16G
    Product Rev : 2.7
    Product SN : 107B99A3
    Manufactured : January 2012
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 300 ns
    TRANS_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: NO
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    FE014E4D4D4331364727107B99A3_295BB806.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
    Writing MBR...
    Block Write CRC Error
    ERROR: Block Write Failed at 0x00000000
    Check your Test Point Soldering!
    ERROR: WRITE FAILED!
    Total Elapsed Time 00:00:00
