mấy bác cho hỏi như thế này có phải đi ổ rồi k ah . eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15770583040 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : KYL00M Product Rev : 1.2 Product SN : 7414506B Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004B594C30304D127414506BAEC9.ext_csd Backup Directory: D:\box setup\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Normal Factory Erase ====================================================== For eMMC Revision 1.2 (for MMC v4.2) and LOWER --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB For eMMC Revision 1.3 (for MMC v4.3) and HIGHER --> This will ONLY ERASE USER AREA ====================================================== This eMMC is: Revision 1.5 (for MMC v4.41) Block Write CRC Error 0x02 ERROR: ERASE_USER_AREA FAILED 0x02
