repair boot samsung easyjtang nhờ ae giúp
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi thanh99, 4/3/16.
  1. 4/3/16 lúc 13:43
    thanh99
    thanh99
    AE ai dùng box này giúp em xíu.tình hình mượn đc cái box câu pinout emmc xong xuôi rồi mà nạp toàn báo lỗi.ai biết nạp giúp e 1 tay:cry::cry:
    gấp lắm rồi
    ID:1 088 691 044
    pass:1548
    cảm ơn ae
  2. 4/3/16 lúc 14:07
    thanh99
    thanh99
    Z3X EasyJtag Software ver. 2.0.7.5
    Loading eMMC Addon Firmware... IO: 2800 mV
    Box S/N: 0303FF213FEF64BA, ,FW Ver.: 01.52
    CMD Pullup Level:412 mV
    CMD Active Level:2495 mV
    HiPower™ mode is off!
    eMMC Device Information
    EMMC CID : 11010034303030373300B7760F0CA264
    EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0
    EMMC Manufacturer ID: 0011 , OEM ID: 0100
    EMMC Date: 10/2015 Rev.0x0
    EMMC NAME: 400073 , S/N: 3077967628
    EMMC NAME (HEX): 34303030373300
    EMMC ROM1 (Main User Data) Capacity: 15028 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    Extended CSD rev 1.7 (MMC Unknown)
    Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
    Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
    H/W reset function [RST_N_FUNCTION]: 0x00
    Backup saved: 400073_3077967628_20160303_1404.extcsd
    Extended CSD rev 1.7 (MMC 5.0)
    Card Supported Command sets [S_CMD_SET: 0x01]
    HPI Features [HPI_FEATURE: 0x01]:
    implementation based on CMD13
    Background operations support [BKOPS_SUPPORT: 0x01]
    Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
    Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
    Data TAG support [DATA_TAG_SUPPORT: 0x01]
    Data TAG Unit Size [TAG_UNIT_SIZE: 0x03]
    Tag Resources Size [TAG_RES_SIZE: 0x00]
    Context Management Capabilities [CONTEXT_CAPABILITIES: 0x7f]
    Large Unit Size [LARGE_UNIT_SIZE_M1: 0x00]
    Extended partition attribute support [EXT_SUPPORT: 0x03]
    Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
    Power off notification [POWER_OFF_LONG_TIME: 0x32]
    Cache Size [CACHE_SIZE] is 4096 KiB
    Background operations status [BKOPS_STATUS: 0x00]
    1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
    Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x66]
    Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0xcc]
    Power class for 200MHz at 3.6V [PWR_CL_200_360: 0xcc]
    Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0xcc]
    Minimum Performance for 8bit at 52MHz in DDR mode:
    [MIN_PERF_DDR_W_8_52: 0x49]
    [MIN_PERF_DDR_R_8_52: 0x00]
    TRIM Multiplier [TRIM_MULT: 0x01]
    Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
    Boot Information [BOOT_INFO: 0x07]
    Device supports alternative boot method
    Device supports dual data rate during boot
    Device supports high speed timing during boot
    Boot partition size [BOOT_SIZE_MULTI: 0x20]
    Access size [ACC_SIZE: 0x08]
    High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x08]
    High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02]
    Reliable write sector count [REL_WR_SEC_C: 0x01]
    High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01]
    Sleep current (VCC) [S_C_VCC: 0x07]
    Sleep current (VCCQ) [S_C_VCCQ: 0x0a]
    Sleep/awake timeout [S_A_TIMEOUT: 0x14]
    Sector Count [SEC_COUNT: 0x01d5a000]
    Minimum Write Performance for 8bit:
    [MIN_PERF_W_8_52: 0x48]
    [MIN_PERF_R_8_52: 0x00]
    [MIN_PERF_W_8_26_4_52: 0x48]
    [MIN_PERF_R_8_26_4_52: 0x00]
    Minimum Write Performance for 4bit:
    [MIN_PERF_W_4_26: 0x2d]
    [MIN_PERF_R_4_26: 0x00]
    Power classes registers:
    [PWR_CL_26_360: 0x55]
    [PWR_CL_52_360: 0x55]
    [PWR_CL_26_195: 0xbb]
    [PWR_CL_52_195: 0xbb]
    Partition switching timing [PARTITION_SWITCH_TIME: 0x0a]
    Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a]
    I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
    Card Type [CARD_TYPE: 0x57]
    CSD structure version [CSD_STRUCTURE: 0x02]
    Command set [CMD_SET: 0x00]
    Command set revision [CMD_SET_REV: 0x00]
    Power class [POWER_CLASS: 0x00]
    High-speed interface timing [HS_TIMING: 0x00]
    Erased memory content [ERASED_MEM_CONT: 0x00]
    Boot configuration bytes [PARTITION_CONFIG: 0x48]
    No access to boot partition
    Boot config protection [BOOT_CONFIG_PROT: 0x00]
    Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01]
    High-density erase group definition [ERASE_GROUP_DEF: 0x00]
    Boot write protection status registers [BOOT_WP_STATUS]: 0x00
    Boot Area Write protection [BOOT_WP]: 0x00
    Power ReadOnly locking: possible
    Permanent ReadOnly locking: possible
    Read Only lock status: not locked
    User area write protection register [USER_WP]: 0x00
    FW configuration [FW_CONFIG]: 0x00
    RPMB Size [RPMB_SIZE_MULT]: 0x20
    Write reliability setting register [WR_REL_SET]: 0x1f
    Write reliability parameter register [WR_REL_PARAM]: 0x15
    Enable background operations handshake [BKOPS_EN]: 0x00
    HPI management [HPI_MGMT]: 0x00
    Partitioning Support [PARTITIONING_SUPPORT]: 0x07
    Device support partitioning feature
    Device can have enhanced tech.
    Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000757
    Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
    General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
    [GP_SIZE_MULT_3]: 0x000000
    [GP_SIZE_MULT_2]: 0x000000
    [GP_SIZE_MULT_1]: 0x000000
    Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
    Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
    Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
    Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
    Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[127]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[126]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[125]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[124]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[123]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[122]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[121]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[120]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[119]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[118]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[117]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[116]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[115]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[114]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[113]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[112]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[111]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[110]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[109]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[108]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[107]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[106]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[105]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[104]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[103]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[102]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[101]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[100]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[99]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[98]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[97]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[96]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[95]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[94]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[93]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[92]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[91]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[90]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[89]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[88]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[87]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[86]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[85]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[84]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[83]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[82]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[81]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[80]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[79]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[78]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[77]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[76]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[75]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[74]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[73]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[72]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[71]]: 0x01
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[70]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[69]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[68]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[67]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[66]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[65]]: 0x00
    Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[64]]: 0x00
    Native sector size [NATIVE_SECTOR_SIZE]: 0x01
    Sector size emulation [USE_NATIVE_SECTOR]: 0x00
    Sector size [DATA_SECTOR_SIZE]: 0x00
    1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
    Class 6 commands control [CLASS_6_CTRL]: 0x00
    Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
    Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
    Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
    Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
    Context configuration [CONTEXT_CONF[51]]: 0x00
    Context configuration [CONTEXT_CONF[50]]: 0x00
    Context configuration [CONTEXT_CONF[49]]: 0x00
    Context configuration [CONTEXT_CONF[48]]: 0x00
    Context configuration [CONTEXT_CONF[47]]: 0x00
    Context configuration [CONTEXT_CONF[46]]: 0x00
    Context configuration [CONTEXT_CONF[45]]: 0x00
    Context configuration [CONTEXT_CONF[44]]: 0x00
    Context configuration [CONTEXT_CONF[43]]: 0x00
    Context configuration [CONTEXT_CONF[42]]: 0x00
    Context configuration [CONTEXT_CONF[41]]: 0x00
    Context configuration [CONTEXT_CONF[40]]: 0x00
    Context configuration [CONTEXT_CONF[39]]: 0x00
    Context configuration [CONTEXT_CONF[38]]: 0x00
    Context configuration [CONTEXT_CONF[37]]: 0x00
    Packed command status [PACKED_COMMAND_STATUS]: 0x00
    Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
    Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
    Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
    Done.
    log detect emmc
    id :
    1 088 691 044
    pass 1548
  3. 4/3/16 lúc 14:48
    chuongha77
    chuongha77
    máy mất boot hay die emmc[​IMG]
  4. 4/3/16 lúc 15:20
    thanh99
    thanh99
    up rom chết anh ak.hiện tại máy ko nhận usb j luôn
