repai oppo 827 cần giúp
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi Hậugiang-gsm, 1/1/17.
  1. 1/1/17 lúc 21:13
    Hậugiang-gsm
    Hậugiang-gsm
    tình hình nhận con oppo 827 lênh chớp tắc câu pinout apter thì báo lổi
    EMMC CID : 90014A483447316404050BA1CE93719E
    EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
    EMMC Manufacturer ID: 0090 , OEM ID: 014A
    EMMC Date: 07/2014 Rev.0x5
    EMMC NAME: H4G1d , S/N: 195153555
    EMMC NAME (HEX): 48344731642000
    Can't init EMMC, Reason: DATA RCV CRC Error
    Check Data Line!
    Done.
    em đục ra đóng vào apter repai rời thì ok logo em nó sao khi repai
    eMMC_tool Suite ver. 1.0.0.42
    Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
    Looking for EasyJTAG box...
    EasyJTAG API ver. 2008
    Setting IO Levels to 2.8V
    Setting frequence to 14 Mhz
    HiPower mode is OFF
    Changelog:
    11.12.2016 (ver 1.0.0.42)
    Fix: Fixed force erase timeouts detection (Universal Factory Format)
    08.12.2016 (ver 1.0.0.41)
    Fix: Bugs that have been found through your crash report
    02.12.2016 (ver 1.0.0.40)
    Fix: Bug with switching ROM
    Fix: Bug with access to GP-partitions
    Fix: Bug when searching for FRP
    Add: Generic / Universal Factory Format (Toshiba, Hynix, etc.)
    30.11.2016 (ver 1.0.0.39)
    Fix: Bug with the smart card at the start of the program
    Fix: Bug when processing sparse image
    Fix: Bug with extract data from contacts2.db
    Fix: Writing for some MTK images
    Fix: Bug when opening MTK-partitions in the Explorer
    Add: Reading tables from emmc on the Factory tab
    (for writing partitions if you do not have a header file)
    Add: Support GP-partitions
    Add: Option "Write all eMMC Regions at once"
    Add: Automatically sending crash reports
    Add: Button "Sending crash report for the current log"
    Add: Notification in the system tray
    Add: Adding ROM2 when reading from the image
    Add: Automatic writing configuration for MTK after flashing
    Add: Some GUI changes
    HiPower mode is OFF
    CMD Pullup Level: 1763 mV
    Error: Previous operation is not finished yet.
    CMD Active Level: 2258 mV
    Can't init device. Reason: CARD Data FIFO Timeout Error
    HiPower mode is OFF
    CMD Active Level: 2279 mV
    HiPower mode is OFF
    CMD Pullup Level: 1773 mV
    CMD Active Level: 2763 mV
    EMMC Device Information :
    EMMC CID: 7001004D4D43303447020858E2D790CE
    EMMC CSD: D04F01320F5903FFFFFFFFE78A400050
    EMMC Manufacture Name: KINGSTONE
    EMMC NAME: MMC04G , S/N: 0858E2D7 , rev. 02
    EMMC NAME (HEX): 4D4D43303447
    EMMC ROM 1 (Main User Data) Capacity: 3628 MB (0000E2C00000)
    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
    EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000)
    Backup saved: MMC04G_0858E2D7_20170101_203542.extcsd
    EMMC Init completed.
    HiPower mode is OFF
    Backup saved: MMC04G_0858E2D7_20170101_203611.extcsd
    Opening file: MT6582_Android_scatter.txt
    The new format of scatter
    config_version: V1.1.1
    platform: MT6582
    preloader.bin
    Found 2 supported eMMC CID:
    name = 'KJS00M' hex = 0x4B4A5330304D [SAMSUNG]
    name = 'H4G1d' hex = 0x483447316404 [SKHYNIX]
    Error: eMMC has a small size
    The size of the last section has been updated
    Warning: Preloader does not contain your EMMC CID. Make sure that your emmc matches the parameters
    HiPower mode is OFF
    CMD Active Level: 2774 mV
    Backup saved: MMC04G_0858E2D7_20170101_203743.extcsd
    Reading from: ROM2 , start: 0x000000000000 , size: 0x000000200000
    Output file: D:\FILES FLASH\EasyJTAG\OPPO R827\EMMC_MMC04G_ROM2_000000000000_000000200000.bin
    eMMC switching to ROM2
    Reading partition...
    Done reading partition. Read speed: 996.77 Kb/s
    HiPower mode is OFF
    Backup saved: MMC04G_0858E2D7_20170101_203847.extcsd
    đóng vào dẩn chớp tắc
    ace nào làm qua xin hướng dẩn giúp thank! all
    Chỉnh sửa cuối: 6/1/17
  2. 2/1/17 lúc 08:04
    hd2shop
    hd2shop
    hình như lỗi ở đây nè thớt
