reapain r831k cần giúp
Thảo luận trong 'OPPO, VIVO, REALME ANDROID' bắt đầu bởi honglinh_daklak, 4/10/18.
  1. 4/10/18 lúc 15:26
    honglinh_daklak
    honglinh_daklak
    em đã tét r831k a11w đều bị lỗi như vậy cần anh em giúp lỗi này
    Setting frequence to 1 Mhz
    CMD Pullup Level: 2062 mV
    CMD Active Level: 3011 mV
    EMMC Device Information :
    EMMC CID: 90014A483447326111013624A843B2DC
    EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
    EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2a , HEX: 483447326100 , S/N: 3624A843 , rev. 0x01
    EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2015
    EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    Extended CSD Information :
    Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
    Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
    Boot Bus Config: 0x00 , width 1bit
    H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
    Supported partition features [PARTITIONING_SUPPORT]: 0x07
    Device supports partitioning features
    Device can have enhanced technological features in partitions and user data area
    Device can have extended partitions attribute
    Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
    Backup saved: H4G2a_3624A843_20181004_152409.extcsd
    EMMC Init completed.
    Operation: Changing GP sizes (final write) ...
    GP1 size: 0 MB , WR_REL: 1 , ENH 1
    GP2 size: 0 MB , WR_REL: 1 , ENH 1
    GP3 size: 0 MB , WR_REL: 1 , ENH 1
    GP4 size: 0 MB , WR_REL: 1 , ENH 1
    HW_PART error. Reason: Zero sizes
  2. 4/10/18 lúc 15:58
    thanhtan88
    thanhtan88
    HW_PART error.
    cứ này lỗi là quăng thui anh
    TrongNguyen132honglinh_daklak thích điều này.
  3. 4/10/18 lúc 16:06
    viettinh
    viettinh
    Thay ổ mới thôi bạn, ổ báo như vậy k repair dc .
    honglinh_daklak thích bài này.
  4. 4/10/18 lúc 16:08
    thanhco
    thanhco
    bỏ thôi thay em khác vào
  5. 5/10/18 lúc 10:39
    honglinh_daklak
    honglinh_daklak
    thank anh em giúp đỡ
  6. 5/10/18 lúc 10:53
    Đình_Nghệ An
    Đình_Nghệ An
    tìm cái file này trong ở save ( bản backup đầu tiên á ) wite lại nhưng chỉ cứu vãn tạm thời ... muốn lâu dài thay mới
  7. 5/10/18 lúc 11:01
    honglinh_daklak
    honglinh_daklak
    sư phụ ơi em hỏi gà chỉ giáo em với bua nay lam vlxd thoi ak anh
  8. 7/10/18 lúc 16:46
    honglinh_daklak
    honglinh_daklak
    lôi động xác ra repain con nào cũng lỗi như vậy anh em giúp đỡ
  9. 7/10/18 lúc 17:43
    TrongNguyen132
    TrongNguyen132
    như a trên nói như vậy là bị ổ rồi k cứu đc
    REPAIR chứ k phải PEAPAIN
  10. 7/10/18 lúc 17:56
    honglinh_daklak
    honglinh_daklak
  11. 7/10/18 lúc 18:51
    Missing You
    Missing You
    dung easy jtag bản thấp repair là đucợ
  12. 7/10/18 lúc 19:47
    D&Dmobile
    D&Dmobile
    đắc lắc pm em ,thay ổ giá rẻ :D,hoạc bán xác em mua
  13. 7/10/18 lúc 23:21
    tuan_queso5
    tuan_queso5
    emmc đi bụi rồi
  14. 8/10/18 lúc 08:50
    Phươngmobilee
    Phươngmobilee
    format đi rồi nạp lại
    chắc dùng đc nửa tháng
    không thì thây ổ cứng mới thôi
  15. 8/10/18 lúc 08:58
    thanhco
    thanhco
    mua ổ củng 160k + tiền công đống vào , p mềm báo giá khách chửi đắt quá éo thay
    TrongNguyen132 thích bài này.
  16. 8/10/18 lúc 09:01
    thaituan_mobile
    thaituan_mobile
    PEAPAIN là làm gì đấy anh.
  17. 8/10/18 lúc 09:17
    gyong
    gyong
    Dùng bản thấp,mấy bán mới đều lỗi hết.
    Mà repair đc 3 ngày bị lại thì thì repair làm gì,thay luôn cho nhanh.
    Đak Lak thay số lượng pm
