readme 5i mbv by ufi box cần giúp ?
Thảo luận trong 'OPPO, VIVO, REALME ANDROID' bắt đầu bởi dobinh, 19/5/20.
  1. 19/5/20 lúc 17:22
    dobinh
    dobinh
    em mới mua box chạy mbv readme 5i rmx2032 lổi như vấy em ko biết nó ko support hay sao nhờ ae biết giúp thank ae...
    Connection status: EHCI:HUB:HUB:USB 2.00 High-Speed
    Interface: UFI High-Speed
    Serial number: 0011-8842-0180
    Boot version: 1.05, FW version: 1.13 (Aug 19 2019 23:46:09)
    Insertion test... Done
    VCCQ not properly connected
    Init bus...
    VCC: 3.3 V, VCCQ: 1.8 V
    Bus: 1 bit (SDR 48MHz)
    Access mode: sector mode
    Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V)
    Card/BGA: BGA (Discrete embedded) - High density MMC
    Manufacturer ID: 0x15 (Samsung)
    Product name: DH6DAB (0x444836444142), rev: 0x02, serial number: 0x3BEEA858
    Manufacturing date: Thg10 2019
    CID: 15010044 48364441 42023BEE A858A6E4
    CSD: D0270132 0F5903FF F6DBFFEF 8E40400C
    EXT_CSD revision: 1.8 (MMC v5.1)
    Partition info:
    Boot1: 4096 KiB
    Boot2: 4096 KiB
    RPMB: 16384 KiB
    User area: 58.24 GiB(62,537,072,640 bytes)
    Cache size: 64 MiB
    Hardware reset function: 1
    Partition configuration: 0x38
    No boot acknowledge is sent (default)
    User area is enabled for boot
    Partitioning support: 0x07
    Device support partitioning feature
    Device can have enhanced technological features
    Device partitioning possible
    Boot configuration protection: 0x00
    Boot bus conditions: 0x00
    Boot area write protection: 0x00
    Power-on write protection: possible
    Permanent write protection: possible
    Lock status: not locked
    Custom moviNAND command is not supported for this device(MMC51).
    Detected: SAMSUNG moviNAND KMDH6000DA-BXXX/64G
    Chỉnh sửa cuối: 20/5/20
  2. 19/5/20 lúc 18:51
    thuytramcb2016
    thuytramcb2016
    tạm dịch không hỗ trợ Custom moviNAND command is not supported for this device(MMC51
  3. 19/5/20 lúc 20:33
    nguyenthanh1020
    nguyenthanh1020
    câu chân chưa chính xác, mình đã làm 2 3 con rồi vẫn ok
  4. 19/5/20 lúc 22:48
    bigbaboi
    bigbaboi
    câu thêm 1 chân 1,8v ok
  5. 24/5/20 lúc 17:10
    dobinh
    dobinh
