như tiêu đề em râipi lu6200 nó lổi zậy Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG LU6200 V1.0.5025.52349] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0006/0x0000 (16, 0x0000D7800000 Bytes = 3.37 GB) Detected an Initialized FLASH2 Chip, ID: 0x0006/0x0000 (16, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body... ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000 anh em làm qua rồi giúp e với
Khởi động lại máy tính, tháo hết box ra trừ riff và bật mỗi riff, cái này do nhiều đứa bâu vô quá nên nó ko flash dc
