Mình mới mua box jtag ,làm con r831k nhưng nó lại báo thế này EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: H4G1d _ 27337216_20170209_1358.extcsd Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2619 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Z3X EasyJtag Software ver. 2.0.7.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1801100957035D93, ,FW Ver.: 01.58 CMD Pullup Level:2134 mV CMD Active Level:2413 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4834473164040501A122007160 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27337216 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: H4G1d _ 27337216_20170209_1400.extcsd Done. Checking NAND Image : G:\Oppo\File\R831K\OPPO R831K BY IMAM MEGA CELL SURABAYA TESTED\OPPO R831K BY IMAM MEGA CELL SURABAYA TESTED\preloader.bin File are not page aligned! Unable to write such file! Running:SAMSUNG: CID patch... Writing CID! Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2732 mV Warinig eMMC is not Samsung! CID Patch may not work on it! Repairing eMMC CID... Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch ! Z3X EasyJtag Software ver. 2.0.7.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1801100957035D93, ,FW Ver.: 01.58 CMD Pullup Level:2134 mV CMD Active Level:2701 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4834473164040501A122007160 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27337216 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: H4G1d _ 27337216_20170209_1408.extcsd Done. Running:SAMSUNG: BOOT and RPMB resize... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2701 mV This eMMC is not Samsung! Done. Z3X EasyJtag Software ver. 2.0.7.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1801100957035D93, ,FW Ver.: 01.58 CMD Pullup Level:2124 mV CMD Active Level:2609 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4834473164040501A122007160 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27337216 EMMC NAME (HEX): 48344731642000 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Running:SAMSUNG: BOOT and RPMB resize... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2124 mV CMD Active Level:2609 mV Can't init device, Reason: CARD Data FIFO Timeout Error Done. Z3X EasyJtag Software ver. 2.0.7.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1801100957035D93, ,FW Ver.: 01.58 CMD Pullup Level:2134 mV CMD Active Level:2712 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4834473164040501A122007160 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27337216 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: H4G1d _ 27337216_20170209_1420.extcsd Done. Running:SAMSUNG: BOOT and RPMB resize... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2712 mV This eMMC is not Samsung! Done. Running:SAMSUNG: BOOT and RPMB resize... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2712 mV This eMMC is not Samsung! Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2712 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Z3X EasyJtag Software ver. 2.0.7.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1801100957035D93, ,FW Ver.: 01.58 CMD Pullup Level:2134 mV CMD Active Level:2402 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4834473164040501A122007160 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27337216 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: H4G1d _ 27337216_20170209_1422.extcsd Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2402 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2402 mV Writing eMMC Register... Written: REG : 177 VAL :0 Done. Z3X EasyJtag Software ver. 2.0.7.5 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 1801100957035D93, ,FW Ver.: 01.58 CMD Pullup Level:2134 mV CMD Active Level:2413 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 90014A4834473164040501A122007160 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27337216 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 Backup saved: H4G1d _ 27337216_20170209_1425.extcsd Done. ROM1 Are not selected , skip writing ROM1 ROM2 Are not selected , skip writing ROM2 ROM3 Are not selected , skip writing ROM3 extCSD Are not selected , skip writing extCSD You must select flash file first! You must select flash file first! Running:SAMSUNG: BOOT and RPMB resize... Z3X EasyJtag Software ver. 2.0.7.5 Skip loading eMMC Addon Firmware CMD Pullup Level:2134 mV CMD Active Level:2413 mV This eMMC is not Samsung! Done. anh em làm quan giúp mình với không rp boot được.cảm ơn anh em
