R2001 repair emmc fail cần giúp
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi MocHoaMobile, 13/1/17.
  1. 13/1/17 lúc 14:45
    MocHoaMobile
    MocHoaMobile
    em xóa xong config partition lại thì fail dòng cuối như vậy là bị gì anh em xem giúp em với
    EMMC CID : 90014A4838473264040503A2BF111288
    EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
    EMMC Manufacturer ID: 0090 , OEM ID: 014A
    EMMC Date: 01/2015 Rev.0x5
    EMMC NAME: H8G2d , S/N: 60997393
    EMMC NAME (HEX): 48384732642000
    EMMC ROM1 (Main User Data) Capacity: 7456 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    EMMC Password Locked: No
    Extended CSD rev 1.6 (MMC 4.5)
    Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
    Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
    H/W reset function [RST_N_FUNCTION]: 0x01
    High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
    Partitioning Support [PARTITIONING_SUPPORT]: 0x07
    Device support partitioning feature
    Device can have enhanced tech.
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
    Backup saved: H8G2d _ 60997393_20170113_1430.extcsd
    Done.
    Z3X EasyJtag Software ver. 2.5.0.4
    Skip loading eMMC Addon Firmware
    CMD Pullup Level:2062 mV
    CMD Active Level:3011 mV
    Box IO Level:3300 mV
    CLK Rate:14000 khz
    Erasing 00400000 bytes from 00000000 ...ROM1
    Erase Done.
    CLK Rate:14000 khz
    Erasing 00400000 bytes from 00000000 ...ROM2
    Erase Done.
    Running:eMMC: Factory Format...
    CLK Rate:14000 khz
    Formatting eMMC card, please wait up to 3 min...
    Setting Service Mode...
    eMMC Format Done.
    Done.
    Running:JEDEC: Partitions config burn...
    CLK Rate:14000 khz
    Partition configuration:
    No enhanced user data area
    User partition write reliability: on
    No GP1 partition
    GP1 write reliability: on
    No GP2 partition
    GP2 write reliability: on
    No GP3 partition
    GP3 write reliability: on
    No GP4 partition
    GP4 write reliability: on
    Card already partitioned
    HW Parts Config Fail.
    với lại anh em cho hỏi thêm con này là loại 4gb hay 8gb vậy
  2. 13/1/17 lúc 14:49
    MocHoaMobile
    MocHoaMobile
    em flash lại bằng flashtool thì lổi 4032
  3. 13/1/17 lúc 14:49
    bigbaboi
    bigbaboi
    8gb và con này đã làm 1 lần rồi à
  4. 13/1/17 lúc 14:50
    chuongha77
    chuongha77
    8g lấy flashtool chạy chưa
  5. 13/1/17 lúc 15:05
    MocHoaMobile
    MocHoaMobile
    để em tải rom 8gb về chạy thử đã nãy em chạy rom 4gb
  6. 13/1/17 lúc 15:15
    bigbaboi
    bigbaboi
    làm easy jtag mà ko biết đọc thông số log à bác thầy bác đâu ?
  7. 13/1/17 lúc 15:31
    MocHoaMobile
    MocHoaMobile
    box này em mới mua nên chưa rành anh ơi thấy log này
    cũng nghĩ là 8gb nhưng muốn hỏi anh em cho chắc ăn anh
  8. 13/1/17 lúc 15:38
    bigbaboi
    bigbaboi
    EMMC ROM1 (Main User Data) Capacity: 7456 MB = 8gb
    EMMC ROM1 (Main User Data) Capacity: 34xx MB =4gb
    EMMC ROM1 (Main User Data) Capacity: 15xx MB = 16gb
