OPPO A91 cph2001 mã bảo vệ
Thảo luận trong 'OPPO, VIVO, REALME ANDROID' bắt đầu bởi ông đen, 17/8/20.
  1. 17/8/20 lúc 15:38
    ông đen
    ông đen
    con này mới ,,anh em có cách nào trợ giúp hoặc có pinout emmc cho em xin với ạ !
  2. 17/8/20 lúc 19:28
    thamtk1992
    thamtk1992
    lên hãng oppo làm Free a ak , khỏi pin out tháo máy gì cho mệt
    javhdông đen thích điều này.
  3. 18/8/20 lúc 08:43
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    đục ổ nhé ufs 2.1 đó bác
    Mã:
    Versions: CPH2001, CPH2021 (International); PCPM00 (China)
    NETWORK Technology
    GSM / CDMA / HSPA / LTE
    LAUNCH Announced 2019, December 20
    Status Available. Released 2019, December
    BODY Dimensions 160.2 x 73.3 x 7.9 mm (6.31 x 2.89 x 0.31 in)
    Weight 172 g (6.07 oz)
    Build Glass front (Gorilla Glass 5), plastic back, plastic frame
    SIM Dual SIM (Nano-SIM, dual stand-by)
    DISPLAY Type AMOLED capacitive touchscreen, 16M colors
    Size 6.4 inches, 100.4 cm2 (~85.5% screen-to-body ratio)
    Resolution 1080 x 2400 pixels, 20:9 ratio (~408 ppi density)
    Protection Corning Gorilla Glass 5
      430 nits typ. brightness (advertised)
    PLATFORM OS Android 9.0 (Pie), ColorOS 6.1
    Chipset Mediatek MT6771V Helio P70 (12nm)
    CPU Octa-core (4x2.1 GHz Cortex-A73 & 4x2.0 GHz Cortex-A53)
    GPU Mali-G72 MP3
    MEMORY Card slot microSDXC (dedicated slot)
    Internal 128GB 4GB RAM, 128GB 8GB RAM
      UFS 2.1
    MAIN CAMERA Quad 48 MP, f/1.8, 26mm (wide), 1/2.0", 0.8µm, PDAF
    8 MP, f/2.3, 119˚ (ultrawide), 1/4.0", 1.12µm
    2 MP B/W, f/2.4, 1/5.0", 1.75µm
    2 MP, f/2.4, (depth)
    Features LED flash, HDR, panorama
    Video 1080p@30fps, gyro-EIS
    SELFIE CAMERA Single 16 MP, f/2.0, 26mm (wide), 1/3.06", 1.0µm
    Features HDR
    Video 1080p@30fps
    SOUND Loudspeaker Yes
    3.5mm jack Yes
    COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
    Bluetooth 4.2, A2DP, LE
    GPS Yes, with A-GPS, GLONASS, BDS
    Radio FM radio
    USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go
    FEATURES Sensors Fingerprint (under display, optical), accelerometer, gyro, proximity, compass
    BATTERY   Li-Po 4025 mAh, non-removable
    Charging Fast charging 20W, 50% in 30 min (advertised)
    VOOC 3.0
    MISC Colors Lightening Black, Unicorn White, Blazing Blue, Red
    Models PCPM00, CPH2001, CPH2021
    Hải Thànhông đen thích điều này.
  4. 18/8/20 lúc 09:32
    Nhật Tân VF
    Nhật Tân VF
    vậy cho khỏe :)
  5. 18/8/20 lúc 15:48
    javhd
    javhd
    Mấy cây máy dựng hay sửa rồi nó có làm k hay máy zin nó mới làm bạn ơi.
    ông đen thích bài này.
  6. 18/8/20 lúc 19:22
    trunghaumobile1
    trunghaumobile1
    Nguyên cây sửa gì cũng được miễn là hàng chính hãng
    javhd thích bài này.
  7. 18/8/20 lúc 20:31
    javhd
    javhd
    Bình dương oppo nó nằm ở tòa nhà becamex tower phải k bác ui.
    trunghaumobile1 thích bài này.
  8. 18/8/20 lúc 21:43
    trunghaumobile1
    trunghaumobile1
    Lầu 3 làm trong vòng 1h
