NoVirusThanks MD5 Checksum Tool 3.9.0.0 + Portable - Kiểm tra mã MD5, SHA-1...
Thảo luận trong 'MÁY TÍNH WINDOWS' bắt đầu bởi Hạo Thiên, 17/12/15.
  1. 17/12/15 lúc 22:49
    Hạo Thiên
    Hạo Thiên
    MD5 Checksum Tool is a software application which was developed specifically to aid individuals in calculating the MD5 and SHA hash for any file or string and compare two items to check if they are different or not.
    User-friendly environment
    After going through a smooth and quick setup process, you come face to face with a minimal and well-organized interface. It is comprised of a small menu bar, a few buttons, some panes to display different information and several tabs so that you can easily access the various options integrated. Although no Help contents are integrated, we are confident that all user categories can find their way around it.
    Generate hashes and copy them
    This software program enables you to easily calculate the MD5, SHA1, SHA256, SHA384 and SHA 512 checksums of any file from your computer or string, by simply writing it or uploading it with the help of a file browser or the “drag and drop” function. It is possible to copy each individual result to the Clipboard, as well as the entire report.
    Compare items and scan a folder
    You can compare two files by simply uploading them, while you can also balance out a hash with an item from the HDD in order to see if they are different or not. Scanning a directory is going to display in a pane all containing items along with their checksums.
    Bottom line
    To conclude, MD5 Checksum Tool is a pretty efficient piece of software when it comes to calculating the hash of any file. All jobs are completed in a timely manner, the amount of resources required is limited at all times, and the interface is dedicated to both power and novice users. If you do not want to go through the installation process, you should know there is also a portable edition you can use, called MD5 Checksum Tool Portable.
    New in version 3.9.0.0:
    • Added Dutch language
    OS: Windows All
    Languages: English, Italian, Greek, French, Dutch, Brazilian, Russian, Korean, Chinese Simplified
    http://goo.gl/TyRVx0
    Portable: http://goo.gl/BOR4xw
    Sưu Tầm
    Trường_Giang VF thích bài này.
  2. 17/9/16 lúc 18:10
    Lâm Apple
    Lâm Apple
    Thank mod chia sẽ phần mềm hửu ích
