nokia 6303 lên chữ nokia rồi trắng màn hình xin đc giúp
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi tuan_queso5, 22/9/10.
  1. 22/9/10 lúc 09:21
    tuan_queso5
    tuan_queso5
    mình có con 6303 bật nguồn lên chữ nokia rồi báo pin yếu sau đó trắng màn âm bàn phím vẫn có nhưng gọi 112 ko có tín hiệu và cho sim vào cũng ko thấy gì .Đây là log của em nó ae xem giúp mình với.thanks
    Mã:
    Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
    Processing file: rm443__10.10.mcusw as MCU
    [BB5,BB5 ALGORITHM] size: 24.67 MB
    Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
    Make sure USB cable, Battery and charger are removed from device.
    Insert USB cable,Battery back to device.
    Insert Charger or Press phone's power button
    Waiting for USB device ...
    [ADL] Polling for ADL device
    [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 22484732
    RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    RAP EM0 ID: 00000296
    RAP EM1 ID: 00000B22
    RAP PUBLIC ID: 14600004EF348E5611F5BB61476DC8DA2A7CC2FE
    RAP ASIC MODE ID: 00
    RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    RAP ROM ID: 273F6D55DFAAF68F
    [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
    [ADL] Update Server code succesfully sent to phone.
    [ADL] Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes
    [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes
    [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 30C1045B
    [ADL] Verifying communication to device OK.
    Erase size: 28.25 MB
    CMT NOR area [00000000-0001FFFF] erased in 0.735 s
    CMT NOR area [00040000-0005FFFF] erased in 0.656 s
    CMT NOR area [00060000-0007FFFF] erased in 0.766 s
    CMT NOR area [00080000-0015FFFF] erased in 4.718 s
    CMT NOR area [00160000-0023FFFF] erased in 4.500 s
    CMT NOR area [01740000-0191FFFF] erased in 9.750 s
    CMT NOR area [00240000-0173FFFF] erased in 1 min 54.891 s
    CMT NOR area [022E0000-0261FFFF] erased in 17.671 s
    Flash programming ...
    CMT PAPUBKEYS: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 (RAP Certificate 140 v.1) written.
    Programming completed in 1 min 31.391 s
    Processing file: rm443__10.10.ppm_v as PPM
    [BB5,BB5 ALGORITHM] size: 7.29 MB
    Erase size: 9.75 MB
    CMT NOR area [01920000-022DFFFF] erased in 53.469 s
    Programming completed in 26.938 s
    Processing file: rm443__10.10.image_v_illuvial as CNT
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.27 MB
    Erase size: 25.62 MB
    CMT NOR area [02620000-029BFFFF] erased in 23.938 s
    CMT NOR area [029C0000-03FBFFFF] erased in 2 min 12.734 s
    Converting UCP blocks to 128 K.
    Programming completed in 48.844 s
    [ADL] Restarting phone ...
    [ADL] Device found: nmwcdc\Nokia 6303 classic USB Generic, ID: E9B6385
    Flashing completed in 9 min 38.922 s
    Phone Type: RM-443 (Nokia 6303 classic)
    SW Version: V 10.10 18-11-09 RM-443 (c) Nokia
    Imei plain: 35150504857279-9
    Product Code: 0568481
    Language Pack:
    - not available.
    This is SL3 phone(Simlock2 format).
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 351505048572799
    Version: SIMLOCK SERVER
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    PROFILE_BITS: 0000000000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    Total time to process is 9 min 42.469 s
  2. 22/9/10 lúc 09:22
    tuan_queso5
    tuan_queso5
    đây là log cua jaf
    Mã:
    JAF version 1.98.63
    Detected PKEY: 90025E31
    Card life counter: 90.70%
    P-key nokia module version 01.02
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
    JAF DCT4/BB5 PRODUCT DIR: D:\UFS_DCTxBB5\products\
    JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
    JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
    USB Cable Driver version: 7.1.29.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Searching for JAF saved location of ini...
    Checking path: D:\UFS_DCTxBB5\products\\
    Searching for default location of ini...
    Checking path: \Products\\
    No ini files found...
    Phone Type:
    MCU Flash file: D:\UFS_DCTxBB5\products\RM-443\rm443__10.10.mcusw
    Phone Type:
    PPM Flash file: D:\UFS_DCTxBB5\products\RM-443\rm443__10.10.ppm_v
    Phone Type:
    CNT Flash file: D:\UFS_DCTxBB5\products\RM-443\rm443__10.10.image_v_silverbrown_128
    Manual mode selected, version can't be checked!
    Booting phone...
    Error sync the phone...
    Detected P-KEY: 90025E31
    Init usb communication...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 08.16.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... .................................................. .................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 2923, APE blocks: 0
    Erasing cmt...
    Processing D:\UFS_DCTxBB5\products\RM-443\rm443__10.10.mcusw...
    Erasing cmt zone 00000000 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00040000 - 0005FFFF ... Erase result: 0000
    Erasing cmt zone 00060000 - 0007FFFF ... Erase result: 0000
    Erasing cmt zone 00080000 - 0015FFFF ... Erase result: 0000
    Erasing cmt zone 00160000 - 0023FFFF ... Erase result: 0000
    Erasing cmt zone 01740000 - 0191FFFF ... Erase result: 0000
    Erasing cmt zone 00240000 - 0173FFFF ... Erase result: 0000
    Erasing cmt zone 022E0000 - 0261FFFF ... Erase result: 0000
    Processing D:\UFS_DCTxBB5\products\RM-443\rm443__10.10.ppm_v...
    Erasing cmt zone 01920000 - 022DFFFF ... Erase result: 0000
    Processing D:\UFS_DCTxBB5\products\RM-443\rm443__10.10.image_v_silverbrown_128...
    Erasing cmt zone 02620000 - 029BFFFF ... Erase result: 0000
    Erasing cmt zone 029C0000 - 03FBFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Sending CMT HASH for ISA+DYNSW
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    MCUSW: V 10.10
    18-11-09
    RM-443
    (c) Nokia
    APESW: (null)
    VariantSW: (null)
    Prodcode: 0568481
    Setting test mode...
    Setting FULL FACTORY...
    Operation took 0 minutes 0 seconds...
    Done!
    Done!
  3. 22/9/10 lúc 09:23
    Minhquan_gsm
    Minhquan_gsm
    thay màn hình đi
  4. 22/9/10 lúc 09:27
    PHƯƠNG ANH
    PHƯƠNG ANH
    cái này không phải màn hình rùi mình có con 5130 cũng như vậy đã tess màn hình vẫn ok nhung biếng quá vẫn chưa làm
    up cho mọi người giúp bạn nè
  5. 22/9/10 lúc 09:29
    Đặng Nguyễn VF
    Đặng Nguyễn VF
    cái này bị cứng rồi đừng làm sw nữa.
  6. 22/9/10 lúc 09:34
    huynhmobile
    huynhmobile
    benh nay` khong phai bi man` hinh` va chuong trinh` dau . anh xem ngay con cpu co 2 duong` ap vio va vcore di ra anh cau no lai la ok . em da lam` thanh` cong may' chu roi
    Nhắc nhở bạn cần viết tiếng Việt có dấu đầy đủ.
    @tuan_queso5: Bạn vui lòng edit lại chữ ký. Không được dùng font chữ màu đỏ.
  7. 22/9/10 lúc 09:44
    LoiThu
    LoiThu
    Trước gặp 1 chú, mở lên báo pin yếu ,rồi trắng màn, tưởng đường màn hình , làm mãi ko xong , câu 1 sợi dây đông từ Bsi sang tụ C2071 đường Bsi nằm bên cạnh ,Hết phim . đã test :D
    Thử đi có gì ..Bá cáo lại nhá
    Chỉnh sửa cuối: 22/9/10
  8. 18/11/10 lúc 17:17
    hon_h46
    hon_h46
    rất hiệu quả cảm ơn bạn nhiều nha mình vừa ok một cây bệnh như vậy đó
  9. 14/6/11 lúc 09:10
    phuocloc00999
    phuocloc00999
    ban oi ban co tẽ thu camera chua?thao camera roi tẽ thu dy ban ~X( :mad:
  10. 14/6/11 lúc 09:14
    Kenmobile_GSM
    Kenmobile_GSM
    vào mục tét sell coi nó báo gì ko
  11. 4/8/12 lúc 16:37
    trankimthuy
    trankimthuy
    cảm ơn mình đang có con bị như vậy thử coi...cảm ơn nhiều nhiều........!
  12. 21/8/12 lúc 22:18
    anhcongmobi87
    anhcongmobi87
    sao em khong thay hinh nao ca cac pro
  13. 21/8/12 lúc 22:21
    anhcongmobi87
    anhcongmobi87
    em cung co con 6303c bi mat chan GNP em cau ra mat sau do mo nguon hien nokia bao bin yeu rui trang man . nhung em khong nhin thay hinh cau cua cac pro dua len j ca ?
    cac pro giup e voi ,em moi vao nghe.
    thank cac pro truoc nhe!
  14. 24/8/12 lúc 19:34
    ngoctrongda48
    ngoctrongda48
    mượn tiêu đề trên ln,mình cũng bị một con nè,đóng up và flash lại rồi nhưng cũng vậy,chạy chương trình thì ko check dc ln,
  15. 24/8/12 lúc 19:40
    ngoctrongda48
    ngoctrongda48
    câu nối tắt 2 áp đó lại hay sao huynhmobile
  16. 24/8/12 lúc 20:07
    ThiênPhu mobile
    ThiênPhu mobile
    bài này lâu rồi mà 22-09-2010 dh
  17. 24/8/12 lúc 20:07
    Tuấn Bình Định
    Tuấn Bình Định
    máy anh bi mất bsi rồi.hôm trước có 1 em đang làm camera,key key hở chân bsi là bi như vây,flash lai cũng not ok,cuối cùng nhìn kỷ thây hở chân bsi,câu lai bsi.gân chân bsi có con trở đó.câu vào đi.chân bsi của dòng máy này cũng có nội trở đó nha,câu bsi ok ak
  18. 24/8/12 lúc 20:21
    muu_sinh
    muu_sinh
    mất con tụ nhỏ gần dường bsi áh, coi thahy hay cau sợ dây đồng từ bsi ra mát test đi .chắc ok
  19. 24/8/12 lúc 20:23
    muu_sinh
    muu_sinh
    thằng khốn nào nào đọc bài đã rồi cũng úp lên cho ace bận tâm nữa . bài của làm ace hố cả làng. khôn nạn thật
  20. 17/1/15 lúc 14:57
    tuananhhd2
    tuananhhd2
    -cảm ơn bạn..đúng là con tụ ấy,không ai ngờ là nó.từ đầu tưởng do cặp..làm cặp lại vẫn thế.nhờ bạn cố vấn và đúng là mất áp bsi ,phía con tụ vẫn có nội trở,câu sợi dây qua đó.đã ok..
