:nhận bật nguồn lên cài giờ thì đơ bấm ko dc để 1 lúc thì tắt, flash máy erro thế là bị dính đèn 2 hông. Thay cặp flash còn sống qua not ok, cặp flash đó đóng qua máy sống thì ok, ai biết bệnh gì chỉ e với, có log nữa nè: Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Files Set for Flashing Card found: S/N : 2F027E88 , v0118 Registered to: winz Connect phone on selected interface... UFS S/N 21124 boot - Ok Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm217__07.30.mcusw PPM : rm217__07.30.ppm_r CNT : rm217__07.30.image_ctv_cn_black Check FlashFiles, Please, wait... Bad file : rm217__07.30.mcusw Bad Flash files detected, will break procedure Connect phone on selected interface... UFS S/N 21124 boot - Ok MCU : rm217__07.21.mcusw PPM : rm217__07.21.ppm_v CNT : rm217__07.21.image_v_choco Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2430000D34966D56B19F855FDDAD646C34800D83 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 01 ERR : 32 : FLASH IC - DAMAGED/NOT DETECTED Major Error , break [2ND BOOT] : CMT : Error , info stage failed ( check connection , HW ) Init Service mode... Wait... Init Service Mode Failed! Certificate read error, try continue flashing... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2430000D34966D56B19F855FDDAD646C34800D83 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 01 ERR : 32 : FLASH IC - DAMAGED/NOT DETECTED Major Error , break [2ND BOOT] : CMT : Error , info stage failed ( check connection , HW ) Connect phone on selected interface... Connect phone on selected interface...
Bệnh sáng đèn bên hôm thì lỗi do nhiều nguyên nhân ,thường do mấy con tụ gần nguồn hoặc lỗi 2 con nguồn sau đó mới đến cặp ,Thtread test cặp sớm quá ,giờ flash lại qua Phoenix xem sao ,múc ver đụng nóc lên .rồi tính tiếp .
e flash 7.30 luôn rồi vẫn vậy Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm217__07.21.mcusw PPM : rm217__07.21.ppm_v CNT : rm217__07.21.image_v Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2430000D34966D56B19F855FDDAD646C34800D83 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 01 ERR : 32 : FLASH IC - DAMAGED/NOT DETECTED Major Error , break [2ND BOOT] : CMT : Error , info stage failed ( check connection , HW ) Init Service mode... Wait... Init Service Mode Failed! Error backup Certificates... Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm217__07.30.mcusw PPM : rm217__07.30.ppm_r CNT : rm217__07.30.image_ctv_cn_black Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2430000D34966D56B19F855FDDAD646C34800D83 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 01 ERR : 32 : FLASH IC - DAMAGED/NOT DETECTED Major Error , break [2ND BOOT] : CMT : Error , info stage failed ( check connection , HW ) Init Service mode... Wait... Init Service Mode Failed! Certificate read error, try continue flashing... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2430000D34966D56B19F855FDDAD646C34800D83 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F [1ST BOOT] : Boot Ok , 62 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 01 ERR : 32 : FLASH IC - DAMAGED/NOT DETECTED Major Error , break [2ND BOOT] : CMT : Error , info stage failed ( check connection , HW ) Connect phone on selected interface... Connect phone on selected interface...
Phương án tốt nhất là kiểm tra mấy cái áp cấp sau cho con u và flash trước rồi mới làm cái khác chứ làm tùm lum hỏng lặng hơn
