Nokia 3 TA-1032 Xóa FRP By CM2
Thảo luận trong 'WINDOWS PHONES' bắt đầu bởi thanhnamPDAviet, 15/9/17.
  1. 15/9/17 lúc 13:18
    thanhnamPDAviet
    thanhnamPDAviet
    Nokia 3 TA-1032 Khóa Xác Minh Tài Khoản Gmail (FRP)
    Mã:
    @thanhnamPDAviet
    Wait for phone...
    Phone found! [ 6 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6737
    BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
    BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x05000000
    BromVer   : 0x00FF
    BLVersion : 0x0001
    PreLoader : Active [ Boot with PL ]
    BootLdrSS : LOCKED with CERT
    Processing DA stage
    DA Select done, will use SecMode DA
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x9B
    NAND Flash : NOT INSTALLED
    eMMC Flash : 514E011336394A32410510520770C0BD
    [WARNING] : MEMORY_eMMC_VALIDATE_FAILED
    Initialize Memory ...
    DRAM already initialized by Preloader
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0x13 , OEM : 014E
    [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
    [eMMC] : FLASH_CID : 13014E51324A393652100541BDC03407
    [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000
    [eMMC] : FLASH_LEN : 0x00000003AB400000
    [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
    DEV RID	: 0xF85F4F295B9F5E4FA8B764A1BFB0186E
    INT RAM	: 0x00020000
    EXT RAM	: 0x80000000 [2 GiB]
    BOOT TYPE  : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    Clear FRP ( Google Reset Protection )
    Clear Ok!
    Done!
    Elapsed: 00:00:12
    Reconnect Power/Cable!
    TrongNguyen132Lê Hưng_vfs thích điều này.
  2. 19/9/17 lúc 08:09
    thanhnamPDAviet
    thanhnamPDAviet
    Nokia 3 TA-1032 Xóa FRP By Cm2 Qua Teamviewer.
    Khách ở xa và không có cm2,share port,xóa frp từ xa done kèo.
    Mã:
    @thanhnamPDAviet
    1. Power Off Phone , Remove battery , Insert back
    2. Insert USB cable. In some cases require hold BootKey
    Wait for phone...
    Phone found! [ 31 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6737
    BromVer   : 0x00FF
    BLVersion : 0x0001
    Processing DA stage
    eMMC Flash : 514E011336394A32190510528B78E0DD
    [eMMC] : FLASH_CID : 13014E51324A393652100519DDE0348B
    DEV RID	: 0xF85F4F29DA80214F581F824996101B42
    SOC VERIFY : C1
    Boot Ok!
    Clear Ok!
    Done!
    Elapsed: 00:00:10
    Mạnh Dũng VF thích bài này.
  3. 19/9/17 lúc 08:47
    Đình_Nghệ An
    Đình_Nghệ An
    cuối cùng là bấm phím gì để boot vậy mod
    công vĩnhlong thích bài này.
  4. 19/9/17 lúc 09:14
    thanhnamPDAviet
    thanhnamPDAviet
  5. 19/9/17 lúc 10:25
    phamculuong
    phamculuong
    Con này boot giống oppo, ae ấn giữ phím + , cắm cable là phone sẽ boot. riêng dòng nokia 5,6 chip qualcomm phải dùng cable Edl giống một vài dòng Xiaomi.
    thanhnamPDAviet thích bài này.
  6. 27/9/17 lúc 08:11
    thanhnamPDAviet
    thanhnamPDAviet
    Nokia 3 TA-1032 Xóa Xác Minh Tài Khoản Gmail (FRP) By CM2
    Nokia 3 TA-1032 Remove FRP Via Teamviewer
    Mã:
    @thanhnamPDAviet
    Wait for phone...
    Phone found! [ 19 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6737
    BromVer   : 0x00FF
    BLVersion : 0x0001
    Processing DA stage
    eMMC Flash : 514E011336394A3216051052ABE8A357
    [eMMC] : FLASH_CID : 13014E51324A39365210051657A334AB
    DEV RID	: 0xF85F4F2978AD1E6C1BA54B9EF5AB0475
    SOC VERIFY : C1
    Boot Ok!
    Clear Ok!
    Done!
    Elapsed: 00:00:15
  7. 9/10/17 lúc 09:42
    thanhnamPDAviet
    thanhnamPDAviet
    Nokia 3 TA-1032 Remove FRP By CM2
    Mã:
    @thanhnamPDAviet
    Operation : Format FileSystem [ v1.58 ]
    Wait for phone...
    Phone found! [ 20 ]
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6737
    BromVer   : 0x00FF
    BLVersion : 0x0001
    Processing DA stage
    eMMC Flash : 514E011336394A32950510526B36DA50
    [eMMC] : FLASH_CID : 13014E51324A39365210059550DA446B
    DEV RID	: 0xF85F4F29257B6E26A4136583BEE81C66
    SOC VERIFY : C1
    Boot Ok!
    Clear Ok!
    Done!
    Elapsed: 00:00:31
  8. 9/10/17 lúc 09:43
    nhatquangd16
    nhatquangd16
    em này thì cứ nhét cab vô là nó nhận nhé các thím...ko cần bầm biếc gì hết
