nokia 110 lỗi
Thảo luận trong 'SỬA CHỮA PHẦN CỨNG.' bắt đầu bởi koikoi, 16/10/16.
  1. 16/10/16 lúc 12:11
    koikoi
    koikoi
    e nhận 1 e nokia 110 gọi đi được không gọi đến được e flash thì nó lỗi như này các bác xem nó bị sao giúp e với ạ
    log e nó đây thank các bác nhiều
    Number of Image Files: 3
    Processing Image File :
    rm827__03.33.mcusw
    rm827__03.33.ppm_s3
    rm827__03.33.image_s3_059N2B3
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    Infineon USB Boot: F00A1FB300020303010100FF
    Sending PBL...
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Setting Transmission Speed Done...
    Flash Chip Manufacturer: Intel Electronics Corp.
    Flash Boot Successful...
    Unique Data: 12001C1520091832
    Original Product Code: 059N2B3
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\351970055472681\351970055472681_114919.rpl
    Certificate Block Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\351970055472681\351970055472681_CERTIFICATE_9CF45C23.bin
    PM Block Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\351970055472681\351970055472681_PMM_PROT_681D9773.bin
    Security Code: 12345
    Data Sections : 04
    Current File : rm827__03.33.mcusw
    Compile Name: rm827__03.33.mcusw_ebl_psi.fls
    Image Type : Main Firmware
    Data Size : 27266440 Bytes
    Sending Certificate Block
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01
    FIRMWARE Erase Block: 0x40000000~0x4001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 131072 bytes
    Data Checksum: 43E7
    Uploading Data Blocks to phone...
    Block Write Successful...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02
    FIRMWARE Erase Block: 0x40040000~0x4005FFFE
    Start Erasing...
    Block Erase Done...
    Data Checksum: 7A82
    Processing Section 03
    FIRMWARE Erase Block: 0x40060000~0x4015FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1048576 bytes
    Data Checksum: EF59
    Processing Section 04
    FIRMWARE Erase Block: 0x40280000~0x41BBFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 25952256 bytes
    Data Checksum: 57D9
    ERROR: Write Flash Failed
  2. 16/10/16 lúc 12:31
    koikoi
    koikoi
    :cry: :cry:
  3. 16/10/16 lúc 12:55
    nguyenbatien
    nguyenbatien
    để file đúng đường dẫn chưa bạn
  4. 16/10/16 lúc 13:19
    Mr.Ch1p
    Mr.Ch1p
    Kiếm file khác flash lại xem có bị lỗi không
    Flash lại lân nữa, đang flash lỏng cáp hoặc hết pin cũng bị vậy
  5. 17/10/16 lúc 08:05
    koikoi
    koikoi
    thử rồi vẫn thế bác ạ.máy thì trả đáng bao nhiêu mà mệt với nó
  6. 17/10/16 lúc 09:02
    vietthanhtt
    vietthanhtt
    file cao nhất là 3.51
    xem lại cáp thế nào,giờ ngỏm à
    múc phonenix cũng ok
    gọi đến ok ,đi báo ko đc thì bạn nên xem lại trong cài đặt,flash vội chi mệt,nằm trong cài đặt cuộc gọi,gửi số cá nhân là mặc định,tắt đi gọi đi sẽ ko đc nhưng đến thì đc
  7. 17/10/16 lúc 09:36
    vannammobile
    vannammobile
    gọi đến không đc mà bác . bị trung tần rồi , flash lỗi thì muc u thôi
