Nó Kìa 3.4_TA1288 Screen passcode and FRP Done
Thảo luận trong 'NOKIA ANDROID' bắt đầu bởi TrinhNgocTrung, 15/2/22.
  1. 15/2/22 lúc 16:26
    TrinhNgocTrung
    Administrator
    TrinhNgocTrung
    Thông tin để ae dù chỉ có V1_Cùi cũng múc OK :D Lưu ý là dòng HDM này không thể Hardreset (It has no wiping option in recovery), và các thể loại vv... Mây ... mây đều bắt trả phí :D Luôn tiện, có BK... Gần... full bằng UFI và Z3 => Anh nào cần cứu nếu lỡ hẹo => cứ alo :D
    Mã:
    Running:Format FRP Partition...
    Z3X EasyJtag Software ver. 3.7.0.20
    Loading eMMC GEN1 Firmware... IO: 3300 mV
    Box S/N: 09FF700D5AAACE38, ,FW Ver.: 01.63
    CMD Pullup Level:2041 mV
    CMD Active Level:2887 mV
    Box IO Level:3300 mV
    CLK Rate:14000 kHz
    Bus Width:1bit,SDR
    HiPower mode is off!
    ---------- eMMC Device Information ----------
    eMMC CID : 15010044503644414203EA2B90FCA762
    eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
    eMMC Manufacturer ID: 0015 , OEM ID: 0100
    eMMC Date: 10/2020  Rev.0x3
    eMMC NAME: DP6DAB , S/N: 3928723708
    eMMC NAME (HEX): 445036444142
    EMMC ROM1 (Main User Data)   Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
    EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
    EMMC RPMB is programmed and written 14671 times
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    EMMC Password Locked: No
      Extended CSD rev 1.8 (MMC 5.1)
    Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
    Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x00.
    H/W reset function [RST_N_FUNCTION]: 0x01
    High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
    Partitioning Support [PARTITIONING_SUPPORT]: 0x07
     Device support partitioning feature
     Device can have enhanced tech.
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
    The protective MBR's 0xEE partition is oversized! Auto-repairing.
    Found valid GPT with protective MBR; using GPT.
    Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
    Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
    Disk identifier (GUID): 21CD6BD5-6948-D703-B075-15B5002C2803
    Logical sector size: 0x200  bytes ,First/Last usable sector: 34,122142686
    Partition info successfully found
    Formatting FRP...
    Detected LINUX(Android) FRP : 0x0047A22000 (512.0KB) formatting...
    Done.
    Detected LINUX(Android) USERDATA : 0x02B0000000 (47.491GB) , formatting...
    Done.
    Done.
    Done.
    Running:Reset PIN/PASS/GESTURE Locks
    CMD Active Level:2897 mV
    CLK Rate:14000 kHz
    Bus Width:1bit,SDR
    ------ Android information ------
    Mount EXT4 fs...
    Unable to mount USER , code : 95
    Done.
  2. 15/2/22 lúc 18:47
    cuibaptieude
    cuibaptieude
    wipe data lụm nhé ae
  3. 16/2/22 lúc 07:21
    kikarik2843
    kikarik2843
    :D là emmc thì v1 v2 gì thì cũng dc hết
  4. 16/2/22 lúc 09:13
    TrongNguyen132
    TrongNguyen132
    ae nào không muốn tháo e nhận làm dịch vụ xoá passcode và frp :D
    lehoangsoft thích bài này.
  5. 6/3/22 lúc 12:28
    minhtri308
    minhtri308
    tới nokia care làm free cho nó lành và zin máy
  6. 6/3/22 lúc 13:02
    TrinhNgocTrung
    Administrator
    TrinhNgocTrung
    Giải pháp mang tính phá hoại và khiến chẳng ai muốn chia sẻ điều gì! Ở tỉnh, ở huyện xa => Mang đi đc ko, và khách có chịu ko?
  7. 6/3/22 lúc 13:47
    trunghaumobile1
    trunghaumobile1
    Nokia 3.4 mã bảo vệ
    Nokia 5.4 mã bảo vệ
    z3161147143259_e89b347cc26fff8371fd254217d4d370. z3229846999284_b1de123009e850dbff93308da66c52ba.
    Pin out Nokia 3.4 Pinout Nokia 5.4
    nokia-3-4-y-5-4-isp.
    dinhhieu444, Crack, BìnhSơn7773 thành viên khác thích điều này.
  8. 6/3/22 lúc 17:16
    thanhco
    thanhco
    chọn lệnh gì vậy mod , bên oppo a3s thì em toàn chọn oppo password reset
    trunghaumobile1 thích bài này.
  9. 6/3/22 lúc 17:26
    trunghaumobile1
    trunghaumobile1
    thanhco thích bài này.
  10. 6/3/22 lúc 20:57
    Service Team
    Service Team
    Còn AE nào ko thích tháo máy liên hệ qua ZaLo em làm dịch vụ từ xa. Và tất nhiên giá cũng ko hề rẻ :D
    2022-03-06_115054.
  11. 20/6/22 lúc 16:25
    Nguyễn Tính VF
    Nguyễn Tính VF
    E có box ufi mà ko biết chọn dòng nào luôn
    Ko có tab wipe data, frp
  12. 20/6/22 lúc 17:11
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    ufi thì bạn chọn như hình còn chọn dòng nào chắc k cần phải hướng dẫn thêm nữa nhỷ
    TrinhNgocTrung thích bài này.
  13. 20/6/22 lúc 20:47
    Nguyễn Tính VF
    Nguyễn Tính VF
    Nó ko hiện mới đau chứ
    57A8BCDC-8847-4846-9BA3-C1A261A2D9AD.
  14. 21/6/22 lúc 16:23
    ThanhThảoMobile
    ThanhThảoMobile
    EasyJTAG v1 mới gặp nhai ok luôn nè
    Formatting FRP...
    Done.
    Detected LINUX(Android) USERDATA : 0x02B0000000 (105.733GB) , formatting...
    Done.
    Done.
    Done.
    Loading eMMC GEN1 Firmware... IO: 2800 mV
    Box S/N: 16FFF013DE7D301B, ,FW Ver.: 01.63
    CMD Pullup Level:2031 mV
    CMD Active Level:2650 mV
    Box IO Level:2800 mV
    CLK Rate:14000 kHz
    Bus Width:1bit,SDR
  15. 18/8/22 lúc 03:06
    lehoangsoft
    lehoangsoft
    giá sao anh trai
  16. 18/8/22 lúc 07:42
    lebinhan2021
    lebinhan2021
    Giá khoảng 300-400k. Muốn rẻ thì chỉ có câu dây thôi a.
    TrongNguyen132 thích bài này.
  17. 18/8/22 lúc 10:19
    công vĩnhlong
    công vĩnhlong
    ae tool làm dc ko mod
  18. 18/8/22 lúc 22:00
    Đỗ Đức Vũ ™
    Đỗ Đức Vũ ™
    câu nhận thì múc được bác
