New Year gift for old RIFF Box I users :)
Thảo luận trong 'THIẾT BỊ HỖ TRỢ SỬA CHỮA.' bắt đầu bởi Star, 6/1/17.
  1. 6/1/17 lúc 00:00
    Star
    Super Moderator
    Star
    Quà tặng năm mới của RIFF BOX 1
    Hello dear members and RIFF Box users !
    We have decided to give all RIFF Box v1 users opportunity to install new firmware and software and enjoy full functionality of upgraded RIFF Box v1, including eMMC access and latest Box Firmwares and DLL-s.
    Q's&A's :
    • What do I need to do now ?
      Download and install latest JTAG Manager (To a new folder) and simply enter Your login details when asked.
    • My account is expired, am I eligible for this ?
      Yes !
    • How long I can use this after activation and firmware upgrade ?
      As long as You keep RIFF Directory intact (eg, not format drive or download new files)
    • How long I will have access to licensing Server ?
      Two weeks (14 days). After this period You still can use all features, but You will not be able to download license for new files.
    • I can't remember my login details [​IMG]
      Please read this.
    • How can I buy activation after "gift" period expires ?
      Please visit www.softmobile.net for more information.
    Latest RIFF JTAG Manager is v1.63
    Latest RIFF Box Firmware is v1.41
    Latest Admin Client is v1.07
    Happy New Year !
    Edit:
    Known Problems and solutions:
    - Firmware update fails with message:
    Code:
    Open serial port...OK
    Connecting to the RIFF Box...OK
    Getting RIFF Box Info...OK
    RIFF Box Firmware Version: 1.41 (RIFFBOX1)
    Connecting to the Updates Server...OK
    Downloading new Firmware from Server...ERROR
    ERROR: Couldn't connect to the Updates Server. Try again later.
    - Solution:
    Close JTAG Manager and delete files from "Download" folder in RIFF directory. Retry Firmware Update procedure.
    - JTAG Manager crashes after installing DLL
    Solution:
    Download single *.riffpkg package first, install it and restart JTAG Manager.
    To prepare everything on Your side for this upgrade, You'll need the following:
      • RJ45 cable
      • 2x100 ohms resistors
      • External source for VCC and VCCQ (Optional)
      • Moorc adapters (Optional)
      • Activation credits (If Your box is older than 6 months)
    RJ45 cable is required to connect RIFF Box to eMMC as RIFF Box RJ45 port is used for this function.
    2x100 Ohms resistors are required as pull up, to increase signal levels and improve stability.
    Extarnal source for VCC and VCCQ is required in case that You don't want to open Your RIFF Box, in order to connect RIFF Box internal VCC voltage source. We know that there are already some adapters on market, which offer this function.
    Moorc adapters are well known, and they offer best at price range.
    Activation credits You can get in exchange for some money. We have too many of those, and we will be happy to exchange some of them to real money. [​IMG]
    RIFF Box RJ45 port pinout:
    1-NC
    2-SD_CLK
    3-SD_DAT0
    4-SD_CMD
    5-NC
    6-NC
    7-NC
    8-GND
    VCC pin is located on RIFF Box motherboard, bottom side. You can locate it if You check attached photo.
    Pull up resistors should be connected from VCCQ to both SD_CMD and SD_DAT0 lines.
    Để sử dụng chức năng eMMC Tháo box ra sửa chút Hàn thêm 2 điện trở 100 ôm từ chân số 3,4 vào chân 9 như hình
    RIFF_MMC_Pinout.
  2. 6/1/17 lúc 00:05
    Star
    Super Moderator
    Star
    Upgrade Firmware DONE
    mobile_1980 thích bài này.
  3. 6/1/17 lúc 00:16
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Quất theo anh này :D
    RIFF Box Firmware Version: 1.37 (RIFFBOX1)
    Server Response: RIFFBOX is Registered.
    Getting License from the RIFF Server...ERROR
    ERROR: Access Denied - Login or Password is incorrect.
    Getting License from the RIFF Server...OK
  4. 6/1/17 lúc 00:18
    Star
    Super Moderator
    Star
    Upgrade FW Box nữa ....
  5. 6/1/17 lúc 00:29
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Ngon rồi anh:)
    RIFF Box Firmware Version: RECOVERY (RIFFBOX1)
    Downloading new Firmware from Server...OK
    Setting Update Mode...OK
    Updating Box's Firmware...OK
    Restarting box, please wait...OK
    Firmware Update Completed OK
    Current Firmware Version: 1.41 (RIFFBOX1)
  6. 6/1/17 lúc 07:16
    mobile_1980
    mobile_1980
    mod ơi em đang bị mắc ở chỗ này
    Solution:
  7. 6/1/17 lúc 07:16
    m1_thewall
    m1_thewall
    em làm không được mấy anh chị em chút được không ?
  8. 6/1/17 lúc 08:03
    nhutlinh1919
    nhutlinh1919
    ok 1 em nữajuy887
    thanhxuanmobi thích bài này.
  9. 6/1/17 lúc 08:06
    thanhxuanmobi
    thanhxuanmobi
    sao mình update báo lỗi không connext sever vẻr mình đang 1.53
  10. 6/1/17 lúc 08:08
    Gsm_songcong
    Gsm_songcong
    Cũng đã ok 1 em Freee rồi nhé anh em khỏi actit emmc
    Các file đính kèm:
    Chỉnh sửa cuối: 6/1/17
  11. 6/1/17 lúc 08:24
    MocHoaMobile
    MocHoaMobile
    tải file về repair thì nó treo như anh này luôn
  12. 6/1/17 lúc 08:27
    Gsm_songcong
    Gsm_songcong
    Tải file riffpkg package firs rồi khởi động lại JTAG nhé bạn
  13. 6/1/17 lúc 08:41
    luyenmobile
    luyenmobile
    đã oke với em nó
  14. 6/1/17 lúc 08:43
    MocHoaMobile
    MocHoaMobile
    anh có file đó không cho em xin với
  15. 6/1/17 lúc 08:51
    HuongLong_236
    HuongLong_236
    update ok hết rồi nhưng chắc phải down hết cái file hay repair về,đến lúc server khóa thì lại ngồi ngó
  16. 6/1/17 lúc 08:55
    Gsm_songcong
    Gsm_songcong
    File đó trong updater của Riff ý bạn loat hết các mục setup của box nhé
  17. 6/1/17 lúc 08:57
    trangthanh-386
    Respected Mod
    trangthanh-386
    vào check update download 1 file nào mà có chữ riffpkg đó là được
  18. 6/1/17 lúc 09:17
    hoangkaka
    hoangkaka
    xác nhận done. ko biết nó khóa lúc nào juy887
  19. 6/1/17 lúc 09:29
    QuocBaoMocHoa
    QuocBaoMocHoa
    đã update ok hình như riff không support repair boot con e160s hả anh em sao search file mà không thấy chỉ có e160l thôi
  20. 6/1/17 lúc 09:46
    thanhxuanmobi
    thanhxuanmobi
    chả có thấy shuppost gi mới. bây giờ shup reep mmc oppo may ra còn gỡ gạt được
  21. 6/1/17 lúc 09:52
    thohocnghe
    Trưởng Bối
    thohocnghe
    Xác chết sống lại :D
  22. 6/1/17 lúc 10:26
    Tùng Đà Lạt
    Tùng Đà Lạt
    anh em giúp với setup giờ nó báo vầy riff box limited (c) 2012 install failed
  23. 6/1/17 lúc 11:10
    Star
    Super Moderator
    Star
    Anh em lấy cả Licence EMMC nữa xử lý được OPPO Treo, Wipe recovery fail, rung dài...
    3mien thích bài này.
  24. 6/1/17 lúc 11:16
    HatCatCongNghe
    HatCatCongNghe
    cái này mà tool ko phải box thì sướng nhỉ
  25. 6/1/17 lúc 11:24
    Gsm_songcong
    Gsm_songcong
    Lại tốn tiền mua adapter emmc rồi
  26. 6/1/17 lúc 11:26
    Star
    Super Moderator
    Star
    Nó có kèm sơ đồ chế đó không phải tốn tiền mua
  27. 6/1/17 lúc 11:59
    3mien
    3mien
    mới up lên done nha ae nhanh tay up lên
  28. 6/1/17 lúc 12:15
    Công_Đức_1368
    Công_Đức_1368
    sao em cài bản mới updata vẫn hiện cái bàn tay .
  29. 6/1/17 lúc 13:25
    thanhco
    thanhco
    c
    cái tool này nó nằm ở đâu các anh ?
  30. 6/1/17 lúc 13:34
    Gsm_songcong
    Gsm_songcong
    Trên tool chính có mục emmc ý
  31. 6/1/17 lúc 13:40
    thanhxuanmobi
    thanhxuanmobi
    hình như phải actimet mới được
  32. 6/1/17 lúc 13:43
    thanhco
    thanhco
    ok rồi anh . mới có pinout của box không có pinout emmc đục emmc ra câu vào đâu . hay là gỏ google tìm pin hở mấy bác?
  33. 6/1/17 lúc 14:11
    Anh Công_Mobile
    Anh Công_Mobile
    suport cả repair mmc ak a ngọc ơi quả này riff lại lên giá rồi
  34. 6/1/17 lúc 14:15
    tuannv1508
    tuannv1508
    Các bác cho em hỏi xíu: RIFF của em connect server xong báo "Verification Request is already Queued" là sao nhỉ?
  35. 6/1/17 lúc 14:18
    Gsm_songcong
    Gsm_songcong
    Nhìn cái lisp emmc cũng khá nhiều nhưng pinout có vẻ không dễ ăn
    Các file đính kèm:
  36. 6/1/17 lúc 14:33
    vudinhhau
    vudinhhau
    riffpkg package firs sao mình tìm mãi không thấy file này nhỉ
  37. 6/1/17 lúc 14:42
    Anh Công_Mobile
    Anh Công_Mobile
    sao e ko update dc hay phải active hả các bác
  38. 6/1/17 lúc 14:50
    Gsm_songcong
    Gsm_songcong
    Anh em nào up lỗi qua chữ kí mình qua temw làm cho vừa làm ok cho mấy bạn qua temw nhé
    Viễn_Thông thích bài này.
  39. 6/1/17 lúc 14:53
    Viễn_Thông
    Viễn_Thông
    thank.....mới bụp ok rồi
  40. 6/1/17 lúc 15:03
    haiumts
    haiumts
    cho em hỏi làm sao backup license của riff để lần sau cài win vẫn dùng được
