Mobistar Lai Yollo MT6735 Reset Privacy Lock By CM2
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 1/7/18.
Trạng thái chủ đề:
Không mở trả lời sau này.
  1. 1/7/18 lúc 08:50
    thanhnamPDAviet
    thanhnamPDAviet
    Mobistar Lai Yollo MT6735 Xóa Mã Bảo vệ Riêng Tư Thành Công
    Mã:
    @thanhnamPDAviet
    Sync...
    Inital Boot Ok!
    BB_CPU_PID : 6735
    BB_CPU_NME : [MediaTek] MT6735_S00
    BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000
    Processing BROM stage
    Settings for BROM configured!
    SecCfgVal : 0x00000000
    BromVer   : 0x0005
    BLVersion : 0x00FE
    PreLoader : NOT Active [ Erased ]
    BootLdrSS : NORMAL with PRELOADER
    Processing DA stage
    DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07
    Sending and initialize DA ...
    Running DA ver.4.2 on BBID : 0x93
    NAND Flash : NOT INSTALLED
    eMMC Flash : 510001154D533237D778004289C0039B
    Initialize Memory ...
    DRAM configured from IDB!
    DRAM initialize passed!
    DRAM size : 0x40000000
    DAgent sent , init HW now
    eMMC FlashIC initialized
    [eMMC] : FLASH_VEN : 0x15 , OEM : 0100
    [eMMC] : FLASH_INF : [SAMSUNG] , BMS27
    [eMMC] : FLASH_CID : 150100513732534D420078D79B036289
    [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000
    [eMMC] : FLASH_LEN : 0x00000001D2000000
    [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
    DEV RID	: 0xF85F4F296DAF5870A835E7DBE87262A7
    INT RAM	: 0x00020000
    EXT RAM	: 0x40000000 [1 GiB]
    BOOT TYPE  : EMMC_FLASH_BOOT
    SOC VERIFY : C1
    Boot Ok!
    USBDL : Init HSUSB Ok!
    Checking data ...
    Process block #1
    Process block #2
    Privacy Lock reset Ok!
    Done!
    Elapsed: 00:01:37
Trạng thái chủ đề:
