Mở Khóa Gmail J510FN By Z3X Box
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi thanhnamPDAviet, 21/2/17.
  1. 21/2/17 lúc 16:23
    thanhnamPDAviet
    thanhnamPDAviet
    Mã:
    Searching Samsung USB Flash interface... COM3 detected
    Setup connection... Ok
    Reading PIT from phone... Ok
    Searching FRP lock... Ok
    Erasing FRP lock... Ok
    Reset done
    For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
    Nhận Mở Khóa Gmail (FRP) Samsung J510FN J5 2016 Online
  2. 22/4/17 lúc 08:41
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J5 2016 J510F Xóa FRP By Z3X Pro
    Mã:
    @thanhnamPDAviet
    Searching Samsung USB Flash interface... COM26 detected
    Reset done
  3. 4/5/17 lúc 08:28
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J510FN Xóa FRP By Octopus
    Mã:
    @thanhnamPDAviet
    Platform: Samsung Android
    Selected port: COM4
    Selected model: SM-J510F
    Reset FRP/ Reactivation lock operation for SM-J510F will delete all user data on the phone (contacts, pictures and others)!
    NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service.
    Connecting to server...
    Connecting to server...Ok!
    Checking resource files...
    Resource files already downloaded.
    Please put the phone into Download Mode and connect USB cable.
    To put SM-J510F into Download Mode, You have to perform the following steps:
    1. Reconnect the battery.
    2. Press and hold "Volume-" + "Home" + "Power ON" keys.
    3. When phone turns on, press "Volume+" key.
    Waiting for phone...
    Firmware write started.
    Writing Custom section...
    Custom section has been written successfully.
    FRP lock is successfully reseted!
    Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset"
  4. 3/7/17 lúc 09:42
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J510FN Khóa Xác Minh Tài Khoản Gmail
    Samsung J510FN Xóa FRP By Z3X Pro
    Mã:
    Searching Samsung USB Flash interface... COM8 detected
    Setup connection... OK
    Reading PIT from phone... OK
    Searching FRP lock... OK
    Erasing FRP lock... OK
    Reset done
  5. 3/7/17 lúc 09:47
    công vĩnhlong
    công vĩnhlong
    ngon....................
  6. 3/7/17 lúc 10:36
    Lê Hưng_vfs
    Lê Hưng_vfs
    ko hiểu sao z3x box của e reset frp lock báo ok nhưng về download mode thì frp lock vẫn on là sao mấy a . e nạp combin rồi bật usb debung lên ok hết mà vẫn on
  7. 13/7/17 lúc 22:35
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J510FN Xóa Xác Minh Tài Khoản Gmail By Z3X Pro
    Mã:
    @thanhnamPDAviet
    Searching Samsung USB Flash interface... COM9 detected
    Reset done
  8. 19/7/17 lúc 08:25
    thanhnamPDAviet
    thanhnamPDAviet
    Mã:
      UNLOCK INSTRUCTIONS:
    	Unlocking with original MSL code:
      1. Phone must be powered on.
      2. Run dialer and type *#0*# (service mode will apear).
      3. Connect the phone to UART cable, choose correct COM port in port settings.
      4. Press 'Unlock' button.
      5. Paste MSL code in new opened window and press 'OK'.
    	Reading codes using sever:
      1. Power on the phone.
      2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
    	 go to 'Settings'-'Developer options' and enable 'USB debugging'.
      3. Connect the phone to PC with USB cable, install drivers if needed.
      4. Select device in ADB settings.
      5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
    	(Login and password will be saved as default after first input and can be changed in settings.)
    	To reset Google account activation lock:
      1. ADB must be activated in any way (you can flash sBoot from combination firmware,
    	 make sure, that you are not upgrade sBoot).
      2. Connect the phone to PC with USB cable, install drivers if needed.
      3. Select device in ADB settings.
      4. Press 'Reset FRP' and follow the instructions in program.
      5. When process done, press 'Back' on phone and perform factory reset from phone settings.
       To reset Google account activation or Samsung reactivation lock:
      1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
      3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
      4. After phone reboot, go to settings and perform factory reset.
    Operation: Reset FRP/React/EE
    Selected model: SM-J510FN
    Software version: 28.8.1
    Reset done
    Done with Samsung Tool PRO v.28.8.1
  9. 13/8/17 lúc 08:47
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J5 2015 J510FN Xóa FRP By Z3X Pro
    Mã:
    @thanhnamPDAviet
    Software version: 29.0
    Reset done
  10. 18/8/17 lúc 08:48
    thanhnamPDAviet
    thanhnamPDAviet
    Mã:
    @thanhnamPDAviet
    Reset done
  11. 3/9/17 lúc 09:02
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J510FN Xóa Xác Minh Tài Khoản Gmail (FRP)
    Mã:
    @thanhnamPDAviet
    Software version: 29.2
    Searching Samsung USB Flash interface... COM24 detected
    Reset done
  12. 8/9/17 lúc 08:48
    thanhnamPDAviet
    thanhnamPDAviet
    Samsung J510FN Khóa Xác Minh Tài Khoản Gmail (FRP)
    Samsung J510FN Xóa Xác Minh Tài Khoản Gmail (FRP) By Z3X Pro
    Mã:
    @thanhnamPDAviet
    Reset done
