Meizu M3 Note Remove Lock Screen By MRT
Thảo luận trong 'CÁC DÒNG ANDROID KHÁC' bắt đầu bởi thanhnamPDAviet, 28/10/17.
  1. 28/10/17 lúc 08:49
    thanhnamPDAviet
    thanhnamPDAviet
    Meizu M3 Note Khóa Mã Bảo Vệ Màn Hình / Recovery
    Meizu M3 Note Remove Lock Screen Via Teamviewer
    Mã:
    @thanhnamPDAviet
    	Disconnect Mobile...
    	Re-Put the Mobile Bettery...
    	Then Connect your Phone to Computer again....
    	Please Make sure Mobile better has Power...
    >>> Searching Mobile Port...
    	Get Mobile Port is:  COM62
    >>> Device driver identification:
    	MediaTek USB Port
    >>> Mobile Has Connect...
    	CPU_NAME: MT6755
    >>> Reading Mobile Hardware Info...Success
    	HW_Inf:  8A00	SW_Inf:  CB00
    >>> Initialization Mobile ...
    >>> Sending Auth File To Mobile...Success
    >>>>Trying Connect to Service verification data...
    Success
    >>> Downloading Boot1 To Mobile Phone...Success
    	Mobile phone status:SYNC...
    	Mobile phone status swtich to :brom...Success
    Success
    	Make sure Mobile status has in :brom...
    	Init Mobile BOOT2 ...
    	=====================Flash Type(eMMC)==============
    	Flash   Size: 0x0000000747C00000 -> 29820M
    	Flash	 ID: 0x90014A4842473461
    	Flash   Name: Hynix_Unknow
    	Flash symbol: HBG4a2
    >>> Swich Mobile to Hight Speed Re\Wr Port...
    	Get Mobile Port is:  COM64
    	MediaTek DA USB VCOM (Android)
    >>> Reading Mobile Map Data...Success
    >>>>Formating Mobile USER Data...
    	ADD(HEX):0x00EB000000	Size(HEX):0x065BBFBE00
    	Corresponding operation completed!!!
    	After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
    LoiThu thích bài này.
